BX1500 HST Leak
/ BX1500 HST Leak #1
BXAK
Member
ALASKA
Kubota BX1500D
My BX1500 leaks HST fluid slowly. Is there a UV dye that is compatible with Kubotas HST fluid?
Thank you
/ BX1500 HST Leak #2
Dont know. Try parking it on a piece of cardboard to see which end and side drips. Could be steering cyl or its hoses, or an axle seal. How slowly?
/ BX1500 HST Leak #3
I don't know of a UV dye. I put John Deere hydraulic fluid dye into my Kubota (HST) hydraulic fluid. It sure makes it easier to see in the sight glass.
/ BX1500 HST Leak
I've been trying the cardboard method for a couple years now (that's how slow). It seems to be from the Hydraulic filter, which I have changed twice since the leaking began. I also replaced the o-ring/washer on the drain plug.
/ BX1500 HST Leak
Useful tip, but my machine has a dipstick and no sight glass. Hopefully someone will chime in about a UV dye. Thank you.
/ BX1500 HST Leak #6
Well, it sounds too slow to worry about. Mine, at 3500hrs leaks about a pint in 2 yrs. I think most is from the steering cyl.
/ BX1500 HST Leak
I tend to agree, except the only way I can get UDT fluid is one seller on eBay. Nobody in Alaska sells it.
/ BX1500 HST Leak #8
i'm sure any of the popular UV dyes for oil/transmission/hydraulic fluids will be fine.
U-View comes to mind,as does Dye-Lite,and many others.
Heck,almost every AC system that has been serviced,and some that haven't,have UV dye in it.
No worries!
The kits come with a blacklight and those yellow glasses that enhance the dye's visual effect.
Is SUDT2 all that's offered in AK,or is it Premium UDT from Canada?
Good Luck!
/ BX1500 HST Leak
No worries!
Good Luck!
Thanks for the reassurance on using an off the shelf dye.
I can't buy any kind of Kubota HST fluid in Alaska. I order SUDT2 from a guy on eBay who lives in the lower 48, haven't found another way to get it.
/ BX1500 HST Leak #10
What do the Alaska dealers sell?
Surely there must be a dealer in Alaska?
We would be happy to discuss alternative fluids.
Alaska has so many different climate zones!
Good Luck!
/ BX1500 HST Leak
Good Luck!
When I called the dealer in Anchorage he recommended a Chevron product, but I could never find it locally. I live on the Kenai Peninsula and we have a mild summer and long, cold winter. I don't think Kubota is very popular here. Bought my tractor with my house and it's been great for light farming and I put a BX2750D on it for blowing snow.
/ BX1500 HST Leak #12
May I suggest posting in the Kubota Owning Operating Forum?
Alaska members are here and may chime in.
I believe member 5030 uses that Chevron fluid.
Other tractor users in your area are using something that works.
Even a local fuel/lubricant distributor will have a suitable product.
Visited the Kenai in 2000,Soldonta,Seward and Homer.
Always wondered what winter is like there.
Good Luck!
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
429904 (A61165)
429904 (A61165)
Adams 16T Tender Body (A63118)
Adams 16T Tender...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
Front and Rear Studded Tires (A63116)
Front and Rear...
