Deere 4020
/ Deere 4020 #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I looked at a Deere 4020 today with a cab. Runs and drives really well, all the glass is there, AC is non-functional but otherwise, it's complete and runs really well. They're asking $8900 for it. Buy it?
/ Deere 4020 #2
Diesel or gas?
power shift or synchro-mesh?
remotes?
tire condition?
hours?
paint condition?
/ Deere 4020
Diesel or gas?
remotes?
tire condition?
Diesel
It's 8 speed forward and has a clutch, not sure what that would be called.
2 remotes
Tires are in really good condition, they've never seen pavement and aren't very worn.
/ Deere 4020 #4
Both type 4020 trans had 8 fwd speeds & foot clutch pedal. Was gearshift pattern zig-zagged(Syncro-range) or in the shape of a "J"(Powershift)? Hyd controls on LH side of dash or RH side of seat? JD cab or aftermarket?
/ Deere 4020
It was a J, controls on right of seat and factory cab.
/ Deere 4020 #7
So you have a late model('69-'72) 4020 with Powershift trans
/ Deere 4020
/ Deere 4020 #10
Why would the cab detract?
Because there was no decent cab available for that tractor. The concept of an isolated cab hadn't been adopted yet, all OEM and aftermarket cabs were dropped onto open operator stations. Vibrations, noise and heat that would escape an open 4020 are retained, reflected and redirect back at the operator. They are hot, loud and uncomfortable, especially without air conditioning.
/ Deere 4020 #11
My BIL had that "J" shift transmission 4020,,
One of the best days of that farm was the day that 4020 LEFT,,!!
The transmission was a nightmare,, it self destructed twice in less than 5 years
The tractor was not abused,, no other tractor on that 1,600 acre farm ever had such a short life.
That transmission is basically an automatic,, like a car automatic, except it did not "shift" itself.
the tractor was perfect for baling hay,, if the hay gets heavy and thick, just shift to a lower gear.
no clutch needed.
/ Deere 4020 #12
Results do vary, but the 8 speed Deere power shift is generally regarded as the first successful and reliable full power shift transmission used in farm tractors. It stayed in production essentially unchanged from 1965 to 1982 and was installed in tens of thousands of tractors if not hundreds of thousands. The most common descriptive adjective associated with it is bulletproof.
/ Deere 4020 #13
That's what I've heard from neighbors, too. I've never owned one myself, but if I needed a tractor that size the 4020 powershift would be on my "go find one" list.
/ Deere 4020 #14
The 4020 is arguably one of the best all around tractors ever made. It has always been one of my favorites.
/ Deere 4020 #15
That's interesting, I've only worked with the open station 4020s.
So what were the fixes for the loud cabs? Were there insulation kits? Could the cabs be removed and go back to being open station?
Is it possible to remove the doors and glass so that the cab becomes more like a canopy? It's easy - and worthwhile - to insulate the underside of a canopy.
/ Deere 4020
I know you can remove the doors and glass and maybe some other panels.
I tend to wear earplugs on equipment these days, something that's happened as I've gotten older. The only exception is the excavator, it just isn't loud
/ Deere 4020
Just got it home...by the time it was all said and done, we paid roughly $7500 for it.
/ Deere 4020 #18
Congratulations. I bet it will serve you well. But do fix that AC.
2004 KENWORTH 10 WHEELER GRAIN TRUCK (A64278)
2004 KENWORTH 10...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
