JD 4300 Won't lift as much
   / JD 4300 Won't lift as much #11
It sounds like the pump is deadheading when I attempt to lift or curl. It's weird, sometimes it will lift normal and other times it won't.
If its only when you attempt to curl, it sounds like an unseated or faulty quick disconnect
   / JD 4300 Won't lift as much #12
I agree with LD1 on this sounds like a quick disconnect failing. If you feather the joystick in an attempt to raise very slowly will the loader lift? Same with curl / dump. If it works at very low speeds this also points towards quick disconnects failing.
The quick disconnect are definitely seated correctly, do you think it is all four quick disconnects?
   / JD 4300 Won't lift as much #14
It's unlikely all have failed
Is this just curl or lift?
Their is two for each....and if a single one is faulty, it will cause that function not to work. Because they BOTH flow fluid when a function is operating. One allows fluid to supply the cylinder and the other allows return. Block either one (like a faulty coupling) and the system will deadhead
   / JD 4300 Won't lift as much #15
If both curl/ dump and lift / lower are failing is there a chance you have a hose crossed between the two functions? This would cause both functions to fail
when you attempt to raise does the loader lift a little then stop?
Do both of the hoses going to lift cylinders get stiff like under pressure?
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
71060 (A49346)
71060 (A49346)
