Anybody attempted to remove skid steer tires that have been foamed?
   / Anybody attempted to remove skid steer tires that have been foamed? #1
tmc_31
Gold Member
Texas
NH TN70D, NH L190
I put new tires on my 2007 skid steer when I bought it in 2015. Now it is time to change the tires. Any suggestions on how to remove the old tires for the rims will be appreciated.
Tim
   / Anybody attempted to remove skid steer tires that have been foamed? #2
I was under the impression that you cant removed the tires if they have been foamed, by I have never tried. My guess is you could chop or shear them off, but getting the bead off the rim will be labor intensive. I think the bead gets "glued" to the rim and could be very difficult to remove.
   / Anybody attempted to remove skid steer tires that have been foamed? #3
I have always heard it was a job for a sawzall.
   / Anybody attempted to remove skid steer tires that have been foamed? #4
Tim
Circular saw with a metal cutting disc. Been there and done that a few times already. Wear eye protection is a must. Burning rubber gases can really gag you, so stand up wind or wear a paint mask with filters.
Depending on the tire size, age of the foam and the foam used, more than 2 cuts could be required.
The sawzall will chock on the steel belts and kill the blade.
Once close enough to the steel rim, hand tools are required.
   / Anybody attempted to remove skid steer tires that have been foamed? #5
You have to saw them off.
   / Anybody attempted to remove skid steer tires that have been foamed? #6
better trade them for 4 rims without tires, someone could use foam filled somewhere, tried removing one years ago and even when we got the tire off the stuff was stuck bad to the rim ended up tossing them
Thanks all, doesn't seem like a job for the faint of heart. The tire dealer said that it would cost about $200 additional to have the old tires removed from the rims.
After your responses and watching a few you tube videos I suspect that is a cheap $200
Tim
   / Anybody attempted to remove skid steer tires that have been foamed? #8
How much are new rims? Is the dealer wanting $200 per tire or total?
   / Anybody attempted to remove skid steer tires that have been foamed? #9
If only it was this easy....
4570man, $200 for all, don't know about the price of new rims.
Ruffdog, I watched that same video. I think there may be some difference between a lawn mower tire and a skid steer tire. I watched a farmer's video where he cut his skid steer tires off with a chain saw.
Tim
40 (A52708)
40 (A52708)
SUV (A59231)
SUV (A59231)
Rooster Weathervane (A55853)
Rooster...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
3650 (A47477)
3650 (A47477)
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
