Still looking for a tractor. What do you guys think of this JD 2350?
   / Still looking for a tractor. What do you guys think of this JD 2350? #1
FreeWulf
Member
Between Portland and Seattle
None now
I had a thread a while back looking for a tractor that we may move to Alaska with.
This thing really ticks a lot of my boxes.
Any thoughts based on the pictures? It's at an upcoming auction. I got the keys and was able to move it around the yard a little.
Fires right up, runs really smooth. No bubbles in the coolant. Oil levels are all good.
Hydraulics, 3 point, PTO all seem to work as they should. 4WD works as well as I can test by raising the front end off the ground and moving forward a little. One set of rear remotes, but of course I couldn't test them.
Steering seems tight. Brakes feel good and work well. Clutch feels good and works well. All the gears seem to work well. Granted I was only able to move a few feet forward and back.
7100 hours showing. I'm not going to be working it super hard, just mowing 10 acres or so, plus probably snow removal and loading and unloading the occasional equipment.
Alternatively there's a David Brown 990 with a loader, 2WD that looks like it will go much cheaper. The auction on it ends on Friday. If I can't get the JD, I'll go look at the David Brown.
   / Still looking for a tractor. What do you guys think of this JD 2350? #3
Looks like a good deal for a mechanically inclined person who doesn't need it to be fully dependable and who enjoys working on tractors. It's been beat, so I'd bet there will be some repair work needed for the next couple of years. I'm assuming that you have money set aside for repairs, a good set of tools, can get shop manuals, and are at least somewhat familiar with diesels, electrics, and closed center hydraulics.
Auctions are a huge gamble, but with some work it could be a nice one. The size, make, and model is certainly what you'd hope for. And 4WD! It's from the era when JD tractors were made to be rebuilt indefinitely, and JD parts are more available than most.
Frankly it's the kind and size of tractor I might go for if I didn't have any tractor, was young enough to have more time than money, and felt like I needed a tractor to get things done. Of course I enjoy mechanical work, and there is a lot of JD support to add to the fun.
I would also not be surprised to find that it definitely has at least one problem and maybe several problems - all of which are obvious enough that they would show up pretty quickly in a longer test run. Otherwise the owner would have sold it himself, instead of at auction. You should make sure that it starts immediately and easily from cold. That's a good general test for any old diesel.
The wide front with PS, and matching 148 FEL is a definite plus, and is probably worth from half to 75% of what that tractor is going to go for. That three point hitch is also the good one, and is a real bonus. Notice that it has telescoping arms. I'm guessing somewhere in 3000 to 6500 $$ range is what I'd expect this tractor to go for at auction.
Cleaned up and running nicely from a private party it would be worth twice that much or more. But it would have to look real good & run nicely to offset that many hours. BTW, by "running nicely" I mean that it would be running well enough that a the seller would feel comfortable letting a prospective customer work it for an hour or so.
I don't know anything about David Brown tractors.
Good luck,
rScotty
   / Still looking for a tractor. What do you guys think of this JD 2350? #4
John Deere 2350​
John Deere 2350 tractor photo
1983 - 1986
2050 Series
Utility tractor
Series:215023502550
2355
Production
Manufacturer:John Deere
Type:Utility tractor
Factory:Mannheim, Baden-Württemberg, Germany
Original price:$20,000 (1986 )
John Deere 2350 Power
PTO (claimed):55 hp
41.0 kW
Drawbar (tested):46.66 hp
34.8 kW
PTO (tested):56.18 hp
41.9 kW
power test details ...
John Deere 2350 Engine
John Deere 3.9L 4-cyl diesel
Fuel tank:24 gal
90.8 L
Engine details ...
Mechanical
Chassis:4x2 2WD
4x4 MFWD 4WD (optional)
Differential lock:rear standard
Steering:hydrostatic power
Brakes:differential hydraulic wet disc
Cab:Two-post ROPS. Canopy available. Sound-Gard cab optional with available heat and air-conditioning.
Transmissions:8-speed partially synchronized
16-speed partial power shift
8-speed power shuttle
Transmission details ...
Hydraulics
Type:closed center
Rear valves:1 or 2
Pump flow:13 gpm
49.2 lpm
Tractor hitch
Rear Type:II/I
Control:load and depth control
Rear lift:2,735 lbs
1240 kg
Power Take-off (PTO)
Rear PTO:independent
live (with reverser)
Rear RPM:540
Engine RPM:540@2382
Dimensions & Tires
2WD Wheelbase:89.2 inches
226 cm
4WD Wheelbase:90 inches
228 cm
Weight:6810 to 8220 pounds
Front tire:7.50-16
Rear tire:16.9-30 (2WD)
Full dimensions and tires ...
John Deere 2350 attachments
front-end loader
2350 Serial Numbers
Location:Right side of main tractor frame, above front axle.
photo of 2350 serial number
Electrical
Ground:negative
Charging system:alternator
Charging amps:55
Batteries:1 (ROPS)
2 (cab)
Battery volts:12
Page information
Last update:March 16, 2017
Copyright:Copyright 2021 TractorData LLC
Contact:Peter@TractorData.com
   / Still looking for a tractor. What do you guys think of this JD 2350? #5
John Deere 2350 Attachments​
1983 - 1986
2050 Series
Utility tractor
Series:215023502550
2355
John Deere 146 Loader
For use on two-wheel drive tractors.
Loader weight:1250 lbs
567 kg
Height (to pin):119 inches
302 cm
Clearance, dumped bucket:93 inches
236 cm
Dump reach:40 inches
101 cm
Dump angle:40°
Clearance, level bucket:112 inches
284 cm
Rollback angle:16°
Breakout force (lift):3404 lbs
1544 kg
Lift to full height (at pin):2282 lbs
1035 kg
Bucket width:60 inches
152 cm
72 inches
182 cm
84 inches
213 cm
John Deere 175 Loader
Loader weight:995 lbs
451 kg
Height (to pin):124 inches
314 cm
Clearance, dumped bucket:104 inches
264 cm
Dump reach:36 inches
91 cm
Dump angle:38°
Clearance, level bucket:118 inches
299 cm
Rollback angle:14°
Breakout force (lift):2681 lbs
1216 kg
Lift to full height (at pin):2015 lbs
914 kg
Bucket width:61 inches
154 cm
73 inches
185 cm
John Deere 240 Loader
Loader weight:1520 lbs
689 kg
Clearance, dumped bucket:100 inches
254 cm
Dump reach:31 inches
78 cm
Dump angle:43°
Clearance, level bucket:120 inches
304 cm
Rollback angle:45°
Breakout force (at pin):3990 lbs
1809 kg
Lift to full height (at pin):2498 lbs
1133 kg
154 cm
73 inches
185 cm
85 inches
215 cm
John Deere 245 Loader
Loader weight:1544 lbs
700 kg
Height (to pin):138 inches
350 cm
Clearance, dumped bucket:112 inches
284 cm
Dump reach:37 inches
93 cm
Dump angle:42°
Clearance, level bucket:132 inches
335 cm
Rollback angle:39°
Breakout force (lift):3546 lbs
1608 kg
Lift to full height (at pin):2339 lbs
1060 kg
154 cm
73 inches
185 cm
85 inches
215 cm
Page information
   / Still looking for a tractor. What do you guys think of this JD 2350? #6
David Brown is an English tractor. I speculate obtaining parts in Alaska would be impossible.
Deere is better than most with parts. I expect that parts for the German built, 35+ year old Deere 2350 will be reasonably available from Waterloo, Iowa but VERY EXPENSIVE. Parts might take 3-4 weeks to reach Alaska.
Outside stored tractors sometimes have wiring gnawed by rodents.
JD 2350 in T-B-N ARCHIVE (three pages)
John Deere 2350 site:tractorbynet.com
   / Still looking for a tractor. What do you guys think of this JD 2350? #7
As Jeff notes above, I'd be giving a lot of thoughts about parts availability: and going forward our supply chains are only likely to get worse. Find out what's in use up in that area: think "spare, used parts." Perhaps also see what the Canadians just south might have available.
Figure that with something older you're going to also have to ensure you're stocked up with TOOLS. Good luck on trying to anticipate on this. Seems that no matter how many tools one has the one that one seems to need at a given moment is one that one doesn't have! Might come down to ensuring there's a good shop around (no matter what direction you're going to have to shell out some money when the inevitable happens).
Thanks for the replies.
Here in the PNW tractors are really expensive. I'm expecting that tractor to go for around $11,000, up to 13,000.
The david brown is a 990, which was the same as the CASE 990. Supposedly you can get parts for them through case. It should go for quite a bit cheaper.
   / Still looking for a tractor. What do you guys think of this JD 2350? #9
David Brown 990 Implematic​
NO LOADER IS SHOWN AS AVAILABLE FOR THIS TRACTOR.
David Brown 990 Implematic tractor photo
1961 - 1980
Model year 1961-19651965-19701971-1980
Utility tractor
Production
Manufacturer:David Brown
Factory:Meltham Mills, Huddersfield, England
David Brown 990 Power
Engine:52 hp
38.8 kW
Drawbar (claimed):43 hp
32.1 kW
PTO (claimed):48 hp
35.8 kW
Drawbar (tested):43.47 hp
32.4 kW
PTO (tested):51.60 hp
38.5 kW
David Brown 990 Engine
David Brown 3.0L 4-cyl diesel
Fuel tank:13.74 gal
52.0 L
Engine details ...
Mechanical
Chassis:4x2 2WD
Differential lock:mechanical rear
Steering:manual
hydrostatic power (optional)
Brakes:differential mechanical expanding shoe
Cab:Open operator station.
Transmissions:6-speed gear
12-speed partially synchronized
Hydraulics
Type:open center
Pressure:2000 psi
137.9 bar
Total flow:7.4 gpm
28.0 lpm
Tractor hitch
Rear Type:II/I
Rear PTO:transmission
live (optional)
Clutch:dry disc
Rear RPM:540/1000 (1.375)
Engine RPM:540@1800 (Low)
540@1100 (High)
1000@2000
Dimensions & Tires
Wheelbase:76.75 inches
194 cm
Weight:4272 to 4312 pounds
Front tire:6.00-16
Rear tire:11-32
990 Serial Numbers
1961:440001
1962:441323
1963:450376
1964:460376
1965:472273
1966:483768
1967:496283
1968:504690
1969:808150
1970:818301
1971:826009
1972:850600
1973:854403
1974:859367
1975:863900
1976:11070001
1977:11080236
1978:11089141
1979:11096828
1980:11104577
how to read serial numbers...
Electrical
Charging system:generator
Batteries:2
Battery volts:6
Page information
Last update:June 4, 2020
   / Still looking for a tractor. What do you guys think of this JD 2350? #10
Do yourself a favor and forget the David Brown. Too many British design quirks, Lucas electrical components, sketchy parts availability. I'm not sure why anyone would think the Deere is beat up, for a 30+ year old tractor with the stated hours I think it looks pretty complete and decent. At this age and those hours I would prefer the simplicity of the base 8 speed transmission over the optional high/low or reverser configurations. I don't think your price estimate is too far off unless you discover a major flaw. Good luck whatever you decide.
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
