Get rid of those bent axles!
   / Get rid of those bent axles! #11
Your "bent" trailers are actually pre-stressed so under loading conditions, a bending moment diagram is nice and straight. Same a pre-stressed concrete beams.
   / Get rid of those bent axles! #12
Perhaps those trailers are purposely designed that way. If the empty trailer always returns to the bowed position the material is not fatigued.
Yah think? ;)
   / Get rid of those bent axles! #13
True!
   / Get rid of those bent axles! #14
I thought everyone would understand the arched trailers. They should have made horses that way also. :)
   / Get rid of those bent axles! #15
REALLY! I'm glad that you guys pointed it out to me as I thought that they could get away with it because the Teamster's lobby was too strong. Can you see the sarcasm & irony this time? :D ;) The clue should have been when I stated
when loaded, that bend straightens right out.
   / Get rid of those bent axles! #16
Nothing goes over your head!
   / Get rid of those bent axles! #17
I think the highly arched trailers I've seen were aluminum.
It would be interesting to see how a trailer-length, lightweight, rigid load is supported on an arched trailer.
Bruce
   / Get rid of those bent axles! #18
Bruce
Not hard to see if you look when the opportunity presents itself. The rigid cargo is cribbed on the deck in various places to provide needed support. The cribbing is of varying heights.
   / Get rid of those bent axles! #19
That's what I figured, but I've never seen it.
Bruce
   / Get rid of those bent axles! #20
My trailer engineer buddy and I have constant disagreements over this. As someone who builds a lot of trailers and axles, I look at pretty much everything rolling down the highway with great interest. IF those who design class 8 flat decks actually DID the calcs to determine camber, most of them did them very wrong. What you post is my observation as well: loaded to near design gross weight with load distributed along the trailer deck length, you need blocking of differing thickness to carry a load flat and straight. Those with very little camber are very close to the right values. BTW: the phrase "pre-stressed" was used in this thread - also not true, just "pre-bent"
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
KOMATSU WA270 (A58216)
2018 Dorsey Dominator 55-Ton Low Boy Trailer, VIN: 5JYLB5537JPD06956, Honda Gas Engine, Electric (A59076)
2018 Dorsey...
2012 PJ Trailers PJFS25 25ft 7 Ton T/A Gooseneck Dovetail Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
