The new Grapple has arrived..
   / The new Grapple has arrived.. #11
Coobie - better think about getting a front grill guard and doing something like this. Sticks, stobs & limbs have a nasty habit of finding your grill, radiator or battery.
That is on my to do list.Thanks,Nice set up you have..
   / The new Grapple has arrived.. #14
I know - for sure - my grill guard has saved me from some kind of damage at least two times. Big 'ol sticks stuck in the expanded metal.
Some times I envy you guys. All that "undercover" on your property. I have 80 acres and its either fields of bunch grass or stands of ancient Ponderosa pines. Very little undercover and ONLY Ponderosa pines. But I do have my five acre lake.
   / The new Grapple has arrived.. #15
Looks like a beast.
I have the 60 inch RK5. Mine was built before they made a few improvements I wish mine had but it has been plenty useful. I also got mine before everyone was experiencing material shortages so it showed up in my driveway 3 days after I ordered it.
My advice to people that say 200 or 300 extra pounds is a deal killer for is you need a bigger tractor.
Just called my Kioti dealer(Michigan Iron & equipment) who is doing the install on my 3rd function he is going to install heavy duty steel mesh on my grill guard.Under cover brush/woods is a blessing and a pain is the butt at the same time.
   / The new Grapple has arrived.. #17
Coobie - better think about getting a front grill guard. Sticks, stobs & limbs have a nasty habit of finding your grill, radiator or battery.
One nice thing about the MTL RK model grapples is they have a solid back to prevent such intrusions. It can also be used as a grader blade. :)
   / The new Grapple has arrived.. #18
My Mid States Attachments grapple also has a solid back.
   / The new Grapple has arrived.. #19
Close to 2761 lbs.I have loaded tires plus wheel weights for lifting capacity.
Good luck with the new grapple. Mine is currently at a local Yellow Freight terminal and should be delivered Monday. Its been a long wait from EA.
You mention loaded tires and wheel weights but its my understanding that real, behind the rear axle, ballast is needed to relieve some of that loaded grapple weight off the front axle. In your case it could be a pretty sizable load on that axle.
a reference
a reference
I have that covered with a 1000 lbs rear ballast weight off my 3 point.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2014 Ford Explorer Limited SUV (A55853)
2014 Ford Explorer...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2017 MEC 1930SE 19ft Scissor Lift (A55851)
2017 MEC 1930SE...
