3-Point Hitch Need advice on top link height with finishing mower
   / Need advice on top link height with finishing mower #21
I don't attach the top link... I never need to lift the whole mower off the ground. The rare time I do hit a rock, raising the 3ph is enough to clear the rock (running only on the two rear tires of the mower). I flex too much in my ditches and over berms.
   / Need advice on top link height with finishing mower #22
IMnot sure but it looks like your tractor has draft control and could possibly be raised up, lifting the toplink up,
   / Need advice on top link height with finishing mower #23
My old 6 ft finish mower has chains and a fixed top link pin to the implement has worked great for 15 yrs,
Someone else stated that and I’m looking in to that. Thank you so much.
I’ll check my draft control as well, thank you.
   / Need advice on top link height with finishing mower #26
Is it possible to bolt the rear of the long arms to the hole in the rear of the bracket on the back of the deck? It looks there are two bolt holes n that bracket. If so, I think it would tilt everything to the rear and have the affect of giving you more space at the pto shaft.
If he does that he will need to move the support arms to the inside. The angle and bend won't allow them to get to the rear holes on the outside as they are.
I have some deep slopes here and I’m concerned about torquing my pto without the top link.
  • Good Post
Reactions: JWR
This is an image of my brush mower when it is sitting on the ground.
My floating toplink on this one is of the other type and prevents the toplink from dropping inside the triangle. However this should give you an idea on where your toplink should be to start with. This position should allow you to lift your deck up and down, you will need to adjust in or out so that it stays level when you lift all the way up and put it down.
Thank you again for your help and the photos! I’m trying that in the morning.
The top link at the tractor does not look right. Did you add something there. The top link could go in a lower hole at the tractor. The braces going to back of the mower could be moved to the other holes and that well pull the top of 3pt top link back. Can the lower link arm hook ups move up and down, maybe you stop them because the 3pt floats up and down. On my woods mowers the top link swings between the brackets, if on top when I pick it up it drops down between the brackets.
It’s all factory. I tried the lower hole but nothing doing. Something is janky with this mower.
I put my original top link on and have the floating link as you see in my photo while all four wheels on the mower are on the ground. I just mowed under the lights of the tractor and plow light and it definitely doesn’t hit the pto shaft anymore. Going over a steep slope it still bottoms out and I can’t pick up the mower except for the front wheels as the floating link has no stopping point and just floats no matter where I adjust the top link. I’m guess for now I’ll just hit the slopes on an angle to try not to bottom out the mower and screw up my PTO. Thanks again for your help, my pto shaft is safe for now, lol. I might end up putting chains on at a later date like a poster suggested.View attachment 710681
   / Need advice on top link height with finishing mower #33
The part that is hitting the PTO is simply too long,,
Cut it, and drill new 3/4" holes,,,
I have owned 4 finish mowers, they have all been like this pic, and work perfectly,,
Notice how short Woods makes that swiveling "U" bracket!!??
Cut, then drill, it will then be perfect.
Here is a pic of that mower on my JD tractor, the top link is nowhere near the PTO shaft.
I was actually thinking about that today but wasn’t sure if I would jeopardize the integrity of the metal. I’ll probably try that, thanks for the photos. A huge help!
Can you roll over your toplink mount at the tractor to drop it down? As in 180 degrees?
It looks like it is just two pins, but does it fit that way?
I’ll check it out in the morning. I think the draft control will keep me from doing that but if I can, are you thinking I’ll have a more level top link?
   / Need advice on top link height with finishing mower #36
My toplink has two positions at the tractor, one is for heavy weight, the other for dragging attachments.
   / Need advice on top link height with finishing mower #37
I'd just use a shorter top link.
  • Good Post
Reactions: JWR
   / Need advice on top link height with finishing mower #38
Cad plans is right, That swivelling bracket is to long , My 5 ft brush hog has that same setup but the bracket is much shorter, That would be an easy fix.
   / Need advice on top link height with finishing mower #39
If you use a shorter top link, the rear of the mower lifts, and will not follow the lawn,,
that will leave areas uncut.
Yes, it will work on a pool table flat lawn,, I do not have that ANYWHERE on my property.
   / Need advice on top link height with finishing mower #40
Might have been because I added ot on an edit.
With the floating toplink point the pivot should still not enter the inside of the triangle, it needs to push out when raising so the deck stays level, if it goes into the triangle you start pushing down and the deck tilts rather than raises.
I am pretty sure you have noticed this before on other attachments when your toplink is too long or short. (If it's too long the attachment tends to curl in towards the tractor)
You realize that all you have to do for it to flop down is go over the crest of a hill right? It doesn't just stay there in all conditions, or even most conditions. Raise the implement and put it down it will fall down.
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
Utility Cart (A59231)
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A60430)
2015 CHEVROLET...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
