check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,166
- Tractor
- 2009 Kubota BX25
Hi, guys, I am having a central AC And I am looking for ideas as to what the cause may be. My AC unit is a Luxaire by York, and is hooked up to my propane powered Payne forced air propane furnace. It was installed in 2002 or 2003. (so the first question is, is it the older RS 22 refrigerant, or the newer stuff?)
In 2017, I had the capacitor replaced. The problem is when I call for air conditioning with the thermostat, the compressor unit does go on, but no cold air comes out, even though I can feel the Plenum being very cold. And the furnace fan will not come on, and if it does very little air comes through the registers. After he does on for a while I can see frost building up on the compressor.
If I call for heat using the thermostat, the burners come on, and then eventually the fan comes on but again very little or no air comes out of the registers.
Any ideas, guys?
Any ideas, guys?
