Ford 3910 Hydraulics Fast/Slow rotator knob
   / Ford 3910 Hydraulics Fast/Slow rotator knob #1
srsnitch
Ford 3910
I need some help understanding how the fast/slow response knob works. The one on my machine seems stuck. What s the secret to making the knob turn. Thanks for your help!
   / Ford 3910 Hydraulics Fast/Slow rotator knob #2
That half round knob is probably just a little stuck from not being moved in some time. I've had to loosen mine up by driving out the little compression pin that holds the knob on and remove knob. Now you can grab the shaft with a pair of vise grips , spray the shaft with liquid wrench , tap the end of the shaft with small hammer and wiggle it back and forth with vise grips. It only rotates about 90 degrees I believe. It adjusts the lift speed of the 3pt hitch unlike a lot of tractors which have adjustable down speeds.
I'll give it a try, Thank You!
   / Ford 3910 Hydraulics Fast/Slow rotator knob #4
It's for draft control reaction speed, not "lift speed" per say. It only comes into play when you're using ground engaging implements like plows and such with draft control. And you have to have your reaction pin in the correct position. That's why the knob frequently "freezes"--Not many folks know how to use it.
The knob on mine was missing so I made a lever. I only get about 30 degrees of movement. I typically leave it on fast but move it once in a while to keep it free.
   / Ford 3910 Hydraulics Fast/Slow rotator knob #5
I use mine to control lift speed with the position control lever. When using my 3pt rototiller. Set it to lower flow , when I raise my tiller out of ground it comes out nice and slow and doesn't leave a divot. It's main function is to control rate of correction for draft control as you said.
   / Ford 3910 Hydraulics Fast/Slow rotator knob #6
I had a 3910 for 14 years. One of the first things I noticed was the only issue with the tractor was that knob would not turn. While I could have worked on it and made it turn everything worked and worked well so I never bothered with it. I always figured if I made it turn the likely I would break something that would lead to a few hundred dollars in parts and several hours to make it all work again, all for the sake of making that knob turn that I had no need to turn.
I would very much say if it doesn't turn but everything works leave it.
RoGator 844 sprayer (A50490)
RoGator 844...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
