Skid steer vs. tractor for hobby farm use
/ Skid steer vs. tractor for hobby farm use
For what its worth. I have a skid and more tractors than most. The skid sits most of the time. Don't get me wrong. It has its use, and as a dedicated small loader its impossible to beat as long as your not concerned about tearing up the ground and the ground is either dry or you have some sort of tracks (without tracks a skid is worthless in muddy conditions.)
I wouldn't want to give up my skid but if it came down to having the skid or a tractor, Id go for the tractor every time.
In your case I would be looking at the largest of compacts (mahindra 5035 comes to mind) or make the move up to a utility tractor. Hay is not only heavy its bulky and puts the weight a long ways out. On my last tractor purchase I looked long and hard at my options and ended up going with a used 2002 TN75D and I have to say I really enjoy that tractor. The power shuttle makes it nicer for chore work than even my 2012 TD5050 with mechanical shuttle. And with filled rears its very stable moving big round bales.
I've used the TN to drag my arenas but its honestly just a bit big for that though it will do it for sure. I usually use either a Kawasaki Mule, or an old Ford 3000 for arena dragging duties. The smaller package over all works better especially in my smaller indoor arena.
If your wanting to move hay on the front loader Id not look at machines less than 5000 pounds. Weight really is your friend here.
Thanks for the input. After meeting with our hay broker, I confirmed that we should have little trouble buying timothy/orchard lg square bales at/under 1000#/ea. (As compared to round bales that can be less dry and double that weight.) They *don't* have a forklift with their delivery semi trailer but it's likely that our first delivery will be only a few large squares and the rest of the truck as small squares, so we can dip our toes in it.
I think by hours, dragging the ring will be the most frequent use of the tractor. We did the 120x60' indoor last weekend with the pickup and the corners went untouched. I suspect a compact will help us get more of it.
David
/ Skid steer vs. tractor for hobby farm use #22
EzyUpHire is a South Australian owned and operated family business that’s committed to saving you time and money on your worksite. Our range of equipment includes scissor lifts, telescopic handlers, knuckle booms and everything in between. We have the industry solutions to increase your worksite’s productivity. Our scissor lift range have narrow access capabilities making them ideal for manoeuvring in tight spaces.
Visit us: Scissor Lift Hire Adelaide | Rent All Terrain Scissor Lift Online Adelaide
/ Skid steer vs. tractor for hobby farm use #23
Great the OP asked the questions in 2013
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
