Lk3054 questions ?
/ Lk3054 questions ? #1
ripper980
kioti lk3054
Hey ! Owner of 1998 lk3054 here.
Anyone have the proper specs on valve clearance gap ?
Also have a kl128 loader attached. Curious on loader valve hydraulic. pressure at the loader valve @ 1500 rpm..
Thxs !
/ Lk3054 questions ? #2
I have a 2004 3054xs; I'm sure the engines are the same TD 1400. The work shop manual lists the valve clearance as 0.18 to 0.22 mm (0.0071 to 0.0097 in) so 7 to 10 thousandths of an inch with no difference between intake or exhaust
Did some searching around and found a LK3054XS manual ...
It has different tighter specs ... is this an update ? or is yours an update ?
/ Lk3054 questions ? #4
I'm pretty sure your researched manual is the updated version as mine does not have the xs notation. The 7 to 10 thousandths should be the correct clearance for your '98 tractor. Thanks for the heads up, as I've not yet checked the clearance on my unit
sent you a message .. :)
/ Lk3054 questions ? #6
I don't have the expertise to e-mailing a complete wsm and at 80 years of age have 0 interest in learning new tricks with computers;, sorry; I can barely turn this thing on and off and am (very careful) where I go on it.
I sent you another message sir.
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
Massey Ferguson 573 (A64126)
Massey Ferguson...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
8' X 16' FARM WAGON (A64276)
8' X 16' FARM...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
