Ladder attached to Loader bucket
/ Ladder attached to Loader bucket #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
Just came across this. I ain't 86 yet so I have time to build one and trim some more tall trees ?? Or at least tie a cable up high. I don't think it is OSHA approved
/ Ladder attached to Loader bucket #3
Lol.
/ Ladder attached to Loader bucket #4
Gee, just think what I could on the V417: :unsure:
/ Ladder attached to Loader bucket #5
I do not know if MONKEYRACK is still in production in Bradenton, Florida but this design is much safer.
Any of the hydraulic lines on a Loader is subject to rupture without notice.
/ Ladder attached to Loader bucket #6
That’s too safe. Prefer a little danger myself. Keeps the blood pumping.
/ Ladder attached to Loader bucket #8
Makes me proud. I thought using my dump trailer for a high lift was maybe not safe for a 70 yr old. I had to fab the inside of the front to have something level to stand on when it was all the way up. With the dump raised and a pole saw I could reach 25 ft easy, maybe a little more. What you have to do when you not rich. LOL
/ Ladder attached to Loader bucket #9
I think that is a good plan. I use the tractor bucket and a pole saw also. Keeps the high stuff trimmed.
/ Ladder attached to Loader bucket #10
This is a good idea until the wife wants to borrow the truck and does not see you up there. o_O
/ Ladder attached to Loader bucket #11
These guys must belong to the same union:
ladder-on-rickety-scaffolding-dangerous-work-environment-1477759263.jpg makeshiftladder.png post-badladder.jpg unsafe ladder on truck.jpg 3a5cf6381d41871d736e39843bbefb16--safety-ladder-work-accident.jpg
/ Ladder attached to Loader bucket #12
So how about this thing on the 2" receiver on your forks.... Hmmm
(no. Don't.)
/ Ladder attached to Loader bucket #13
Wow. I had contemplated putting my ladder on the ground but using the loader merely to lean it against, and rejected the idea as being too uncaring toward my heirs. Now I'm thinking I should put it in the bucket with guys to the canopy, and carry rocks to throw at the hydraulic controls.
/ Ladder attached to Loader bucket #14
On occasion, I'll use the FEL bucket to stabilize a ladder, which is set up in the usual way on the ground. I tie the ladder to the side of the bucket to keep it from sliding sideways.
/ Ladder attached to Loader bucket #15
I gotta give a nod to the payloader/manlift combo. That's ingenious!
/ Ladder attached to Loader bucket #16
I've been known to use the bucket on the ground as a flat, level, solid spot for the base of the ladder.
/ Ladder attached to Loader bucket #17
I'm not as adventuresome as some of the setups above but I like to use my CarryAll and TnT to make a level base for the ladders on uneven ground.
gg
/ Ladder attached to Loader bucket #19
I’ve done a similar setup.
/ Ladder attached to Loader bucket #20
I did this exact thing once with a step ladder and an articulating loader when I was working as an electrician for the state 30 years ago. Needed to change a light bulb on the boat ramp and couldn't reach it otherwise. Put the ladder in the bucket, tied it to the pole, and lifted it up. Then shimmied up the loader into the bucket and climbed the ladder. It worked well. LOL
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
Trek (A65640)
Trek (A65640)
