Drivetrain clacking and locking up
/ Drivetrain clacking and locking up #1
kw00
Branson 2400
Branson 2400 manual gearbox. I have a clacking noise in the drivetrain when the clutch is engaged. It occurs even with all shifters in neutral and regardless of MFWD. Occasionally it will lock up and kill the engine, again even in neutral. If I disengage the clutch and lay underneath I can reproduce the noise by hand spinning the propeller shaft. Unfortunately I can't figure out which end the problem is coming from without removing it, because it carries the sound. Does this sound familiar? Could it be a ball joint at one end or the other?
/ Drivetrain clacking and locking up #2
From your description, looks like the noise comes from inside the transmission and most likely it's a broken tooth on one of the gears. Once it gets to that particular spot, it either kills the engine or makes a heck of a bad noise.
I was checking the service manual for that tractor and looks like that tractor uses sliding mesh style transmission, which means the gears will slide to engage whatever gear you choose.
This kind of important because you mentioned that it will do it even with everything in neutral. With that being said, the only other gear that will be spinning while everything else is in Neutral is the reverse idler gear. I suspect this is where your problem resides, either a broken tooth on the idler gear or a broken tooth on the gear of the primary shaft that meshes with the reverse idler gear.
The noise was initially worse in reverse. Does that support your theory? I wonder how that could have happened?
/ Drivetrain clacking and locking up #4
It kinda does. As for what caused it, I really don't know.
Did you bought this tractor new? How many hours does it have right now?
Bought it used. It has 220 hours. Is it reasonable to fix it myself? I'm pretty mechanical, but never worked on a transmission.
/ Drivetrain clacking and locking up #7
I believe this is the correct service manual for your tractor. It might give you an idea if it's something you can work or not.
I was going through that manual and found out that that model has the bellhousing separated from the actual transmission and rear end. Then just uses a subframe to connect everything together.
On the bellhousing side, it has a gearbox with just two gears. There is a possibility that your issue may be there too. One way to check, is to disconnect the shaft that goes from the bellhousing gearbox to the input shaft of the transmission. Then with the clutch depressed like tested before, rotate the shaft of this bellhousing gearbox and pay attention to any weird noises or something weird while rotating.
That was going to be my next step. (Just waiting for the temperature to drop.)
/ Drivetrain clacking and locking up #9
Kw
Which propeller shaft are you spinning by hand? The going to the front axel or one from engine/clutch assembly?
reason for asking is that on my 2400H the input bearings on the front axel input shaft failed at low hours but this just locked up the front axel and never stalled the engine
is it possible one of the shift forks is out of adjustment so trans is being locked in two gears occasionally?
good luck on getting this resolved
/ Drivetrain clacking and locking up #10
A mechanic's stethoscope is a handy tool for finding the location of mechanical problems.
A long screwdriver also works as does a section of air/gas/heater hose. Just hold one end to your ear and touch the other end in the area where the noise is coming from.
oldnslo:
It's the shaft from the clutch to the trans. The gears seem to shift and work solidly. The lockups occur regardless of gear selection, including neutral.
bigtiller:
The problem here is the shaft is transmitting the sound so well I'm not sure I could identify it with a stethoscope. I'll just have to pull the shaft to narrow it down.
ptsg:
Thanks for the manual link. That is much more thorough than the one I found previously.
Thanks for all the help and well wishes so far. Another 98 degree day, so it'll have to wait.
/ Drivetrain clacking and locking up #12
oldnslo:
bigtiller:
ptsg:
That's where they shine, try it.
Is it possible to uncouple the propeller shaft without separating the tractor? It has metal covers over the couplings which are pinned to the shaft. I've removed the pins but haven't been able to slide the covers back to expose the couplings. Should they just slide back up the shaft? Not sure how to push them back without risking damage to couplings. The front one slides back and forth a little, the rear one seems frozen to the transmission shaft end and the shaft slides in and out of it just a little.
After using a screwdriver to listen, I do think it's slightly more likely the problem is at the clutch end.
/ Drivetrain clacking and locking up #14
I was checking the disassembly pictures of the service manual and it does look like it has to be split to take the shaft off. The couplers that look like a constant velocity joint won't be able to slide back even if there was enough spline length. The hub inside will just hit the tip of the shaft.
This looks like a formidable task, especially for someone with no available concrete. May have to haul it 150 miles to the nearest dealer.
/ Drivetrain clacking and locking up #16
You can split it on a couple sheets of plywood lying on reasonably level, flat dirt if you're motivated to take the task on yourself.
Thanks for that. That is what I ended up doing. (Actually OSB siding.) Broken gear on the main gearbox input shaft.
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2001 JOHN DEERE 770CH MOTORGRADER (A62129)
2001 JOHN DEERE...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2012 John Deere 135D Excavator (A61166)
2012 John Deere...
832856 (A61166)
832856 (A61166)
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
