rebuild selective control valve, JD 750 with 67 loader
   / rebuild selective control valve, JD 750 with 67 loader #11
Looking at your parts drawing Jim, mine look like part #7 rather than part #10. Haven’t checked closely enough on what sort of sealing arrangement inside but mine have the knurled outer which pulls back.
   / rebuild selective control valve, JD 750 with 67 loader #12
Breakaway coupler(item 7) is part # AL27026 & A WHOPPING $186 USB. If it was my tractor I would be adapting some generic breakaway couplers not the high $$$$$$ ones from JD
   / rebuild selective control valve, JD 750 with 67 loader #13
One can only imagine what the $aud will be then. They do look like they just sit in the block so I wonder if I can get a couple of iso ones that fit. That way I could do away with adapters as all my other gear is iso bar the 2130.
I see a seal and snap ring on the back of the #7, maybe that’s what is letting oil leak through?
   / rebuild selective control valve, JD 750 with 67 loader #14
Hey Jim just checked, would you believe part #7 is only $171 aud?
Cheap as chips, I’ll get a dozen!
   / rebuild selective control valve, JD 750 with 67 loader #15
Here's the JD part # for ISO coupler that fits your tractors bracket AL26972 $38.55 USD
   / rebuild selective control valve, JD 750 with 67 loader #16
I saw that variation there in parts with iso written there.
Here it has been substituted with AL174797. $64. Not worth the time fixing for that price.
   / rebuild selective control valve, JD 750 with 67 loader #17
Sure have Zebra. This is what I found.
Also shows this one in my tech manual.
I never knew there was an economy component option.
I guess it will be easier to rebuild as reading shows people have lots of trouble with the small o rings top and bottom of the locking shaft.
Jim, do these economy scv’s work as well or do they have a tendency to remove themselves?
I would think being able to pull out could save me some costly repairs in the long run.
I was replying to the original poster about his valve, not you about your coupler.
   / rebuild selective control valve, JD 750 with 67 loader #18
Sorry for that.
@Zebrafive thanks for sharing that info. I've circled back to this project, so will work back to find your post. Will report back as I move forward.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
UNKNOWN  UTILITY TRAILER (A55745)
UNKNOWN UTILITY...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
