Electronic Ignition for M-F with Continental gasoline engines
/ Electronic Ignition for M-F with Continental gasoline engines #1
can do
Gold Member
Nokesville Va.
M-F1526,M-F50
Hey fellow TBN members ! This is for M-F owners who are tired of points & want to do a simple conversion to a electronic ignition & use the stock distributor, cap,& rotor. Benefits set your timing once & forget it plugs are less prone to fowling, & all you need to check is the distributor cap & rotor button for wear,& spark plugs last 2 to 3 times longer.o_O I've been using them on my M-F 50 for 22 years! & have replaced cap & rotor twice & plugs once & she gets used year round (y). It'a ( Pertronix ) brand you will need to get the no. of your distributor located at the base it's a tag recommendations, New 8mm plug wires ,Pertronix Flamethrower coil. Best place to get the the Pertronix & coil as far service & price is CBS Performance & there website is www.cbsperformance.com If your still using your tractor as a working tractor & plan to keep it & want reliable performance it's a good investment IMHO:cool:. I will follow up with a picture of the install in place;).
I guess everybody still likes points :unsure: .
/ Electronic Ignition for M-F with Continental gasoline engines #3
Hey fellow TBN members ! This is for M-F owners who are tired of points & want to do a simple conversion to a electronic ignition & use the stock distributor, cap,& rotor. Benefits set your timing once & forget it plugs are less prone to fowling, & all you need to check is the distributor cap & rotor button for wear,& spark plugs last 2 to 3 times longer.o_O I've been using them on my M-F 50 for 22 years! & have replaced cap & rotor twice & plugs once & she gets used year round (y). It'a ( Pertronix ) brand you will need to get the no. of your distributor located at the base it's a tag recommendations, New 8mm plug wires ,Pertronix Flamethrower coil. Best place to get the the Pertronix & coil as far service & price is CBS Performance & there website is www.cbsperformance.com If your still using your tractor as a working tractor & plan to keep it & want reliable performance it's a good investment IMHO:cool:. I will follow up with a picture of the install in place;).View attachment 700188View attachment 700188
The Petronix CD ignition works for some (if not all?) Ford 8N's also.
Hey fried1765 did You post this on the wrong site :unsure: ? If it needs to be posted on the vintage Ford tractor site I'll post it for You;).
/ Electronic Ignition for M-F with Continental gasoline engines #5
Nope!
Can't quite understand why anyone would object to my noting that there are also other Petronix applications.
Simply offered for the potential benefit to others, no matter which tractor or engine they may have!
I didn't think it was inappropriate, I thought You miss posted it that's all ;)! so I took the liberty to post it on the Ford tractor vintage site so more members could easily find it ,& that seems to make sense IMHO not that I would own anything Ford:LOL::LOL::ROFLMAO:lol ! Seriously though that's where I would look 1st for any of my aftermarket needs for my tractor & the 1st thing I look under is the manufacture for parts & then maybe a + reference. In hind site we are both trying to help fellow members & that's a good thing(y).
/ Electronic Ignition for M-F with Continental gasoline engines #7
I've been using the Pertronix EI setup on my MF 35 Utility for a few years. One of THE BEST upgrades I did. Hot, fat blue spark that snaps hard, easier ignition from a dead cold start in winter, 100% recommend to anyone on the fence about it. Couple it with a nice one-wire alternator and coil (I still run original coil) and you'll notice a serious difference.
/ Electronic Ignition for M-F with Continental gasoline engines #8
Pertronix have been around for many years. Have installed them on many old cars and old equipment and tractors.
BTW... you dont need to replace plug wires or the coil to use Pertronix. just remove the points and follow directions installing the Pertronix unit.
/ Electronic Ignition for M-F with Continental gasoline engines #9
Forgot to add.... if your battery source is a resistored wire run a battery voltage wire direct from the key switch.
Hey Rebeldad1 The plug wires & coil where merely a suggestion & not a requirement as I wanted better voltage to the spark plugs & had to go with red to match my tractor :cool:.Thanks for the input(y).
Hey shaeff ! I totally agree with You & the coil & spark plug wires are merely a suggestion & not a requirement I went that route for higher voltage to the spark plugs & of course they had to be red to match the tractor:cool:thanks for your + input(y).
/ Electronic Ignition for M-F with Continental gasoline engines #12
no problem. just wanted others to know its not required. a great upgrade
/ Electronic Ignition for M-F with Continental gasoline engines #13
Quick question for Can Do, what is your timing set to at idle, I also have the Pertronix system installed om my 1955 TO35 and i'm troubleshooting to odd sputter, I checked my timing and at idle it 30 degrees, normally with points the idle timing would be 6 degrees, and 26 degrees at high RPM.
Hey SCOOBIEGUY ! Welcome to TBN, Your timing is set at the same as if You still had points & according to my shop manual for my 1959 M-F 50 that would be at 6 degrees BTDC @ 450 rpm & maximum advance would be at 2000 rpm 2 degrees BTDC. How long have You had the Pertronix installed ? Also will need to check everything as far as wiring connections at the distributor ,cap ,rotor, plugs , & plug wires, Also are You using the same original coil :unsure: These are just a few things that could be causing your sputtering.When I installed mine I decided to rewire everything & upgrade the plug wires & put the flame thrower coil in ( Pertronix ) & I have never had to set the timing again. I hope this is some help to you. & feel free to contact me again & let me know what You found out;). Oh! one other thing if You live in a high altitude area the timing would be different(y).
/ Electronic Ignition for M-F with Continental gasoline engines #15
If you add your general location to your profile it may help others to help you.
/ Electronic Ignition for M-F with Continental gasoline engines #16
Thanks CAN DO for the follow on proper timing with pertronix setup. I have the flamethrower II coil 0.6 omhs, i'll change the plugs this weekend, I had misadjusted carb that was causing soot on the plugs, I cleaned them up and it seemed to better.
I'm the second owner and the previous gentlemen that owned it passed away before could ask him questions about the pertronix setup.
Last year I changed all fuel lines, cleaned the tank, and replaced the fuel bowl and I have good flow to the Carb.
I also fixed my rich condition by resetting the carb settings per
Marvel-Shebler:
Idle Air: Approx. 1 full turn open from closed or until the engine idles smoothly when warm.
Main Jet: 1-1/4 turns open-fine tune after she warms up to a smooth idle.
Next, I will check for intake manifold and carb flange leaks, using a propane bottle and seeing if the RPMs go up.
Finally I plan to check the valve clearances, but the gas tanks has to come off again
Marvel-Shebler:
Hey SCOOBIEGUY ! Sounds good I did replace my carb. about 5 years ago whoever the original owner was striped the drain plug at the bottom & I didn't want to keep removing the carb. to clean it out & the new 1 works fine & I'm glad I replaced it works great the whole engine runs like it's fuel injected & starts right up all the time:cool:. Before You do a valve clearance check check to see how she runs with the new plugs in. & I had the fuel tank off a few times myself I think it's a pretty easy job, I've owned My M-F for 25 years now & I wouldn't trade for the anything it's just so dependable (y), Even tough I bought a brand new one in 2018 a M-F 1526 I like the 50 as much as my new one.IMG_20201003_134009.jpg
/ Electronic Ignition for M-F with Continental gasoline engines #18
Looks like changing the plugs did the trick sputtering practically gone, used tractor for 3 hours to move 20tons of gravel with back blade.
Previous ones had fouled up, I cleaned them with a wire brush and carb cleaner but I guess that wasn't enough.
I used Champion D16 plugs because that is what was installed originally.
I see some using Autolite 3116 what are you guys running on your continental Z134 gasser?
/ Electronic Ignition for M-F with Continental gasoline engines #19
It's July!
Didn't realize you would still need chains in Ontario.
Must be mighty FAR NORTHERN Ontario!;)
/ Electronic Ignition for M-F with Continental gasoline engines #20
Good one fried1765
I don't have a flat spot on my property, without 4WD I leave the chains on all year, better traction in the forest when skidding wood and dragging rocks :)
This 65 year old tractor cost me 1/6 of a new one and its really strong and serves me well.
If only it had power steering, it just means I have stronger arms I guess.
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2018 International HX620 Quint Dump (A62613)
2018 International...
2020 MACK GRANITE QUIT AXLE DUMP TRUCK (A59906)
2020 MACK GRANITE...
2014 JOHN DEERE 50G EXCAVATOR (A62129)
2014 JOHN DEERE...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
