Hydraulic fluid for topping off and for replacement
   / Hydraulic fluid for topping off and for replacement #11
it should list it on the side .
this is what i use .
   / Hydraulic fluid for topping off and for replacement #12
I use the Mobil utf at tractor supply. Rated GL4. My dealer told me to just look for JD J20C spec. Through my research all the fluids I found J20C spec where also GL4 spec.
Thank you
   / Hydraulic fluid for topping off and for replacement #14
My tractor deal came with the fluid/filters for my first hydraulic fluid change. So ..... obviously it was Kubota branded.
I've continued to use Kubota branded engine oil/hydraulic oil/filters. There is not that much difference in price. And it does not require cross-referencing of products.
   / Hydraulic fluid for topping off and for replacement #15
I use Shaeffer simplex 315 supreme. Same as udt supreme, which is the Kubota spec. Every brand calls the oil a different name. LS calls it something else.
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
gravely riding mower (A55758)
gravely riding...
KMC 4R TOOLBAR (A52708)
KMC 4R TOOLBAR...
2019 GALYEAN...
1087 (A58374)
1087 (A58374)
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
