How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #1
macecase
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
I bought a 4630 tractor and LOVE it. It has a ton more power than what I'm used to.
However, as I moved to mowing this year, I find that the flail mower doesn't quite fit. The lift arms don't come together close enough to hook it up (see photo). I know I could probably remove the blocks that reduce movement but I don't want to do that.
My question is, how do I connect this? Is there an adpater? Or, do I have to remove the blocks to get the lift arms narrow enough to hookup?
Bob
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #2
I don't know about the physical connection but suggest you determing if the mower will handle the horsepower of your new tractor.
The tractor has a 1000 rpm pto. I have a 540 adapter for it and plan to run it slower on the RPMs.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #4
Take the blocks out. Before you raise the 3ph all the way up make sure it doesnt spread the arms back out to stabilize it into the transport position.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #5
Removing the blocks is the easiest way to get the room you need. As per above make sure the lift arms don't spread as you raise the lift arms to the top. You will regret it if they do and your mower is attached.
The tractor is a bit overkill for what you want to do with it.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #6
That's why you can by those size tractors for almost nothing around here. They are just too large for what most people buying tractors nowadays need and as good a tractor as they were they are just not suited for farming anymore.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #7
Not being a smart alleck but those tractors will always be suited for farming by people who are farming for a living , maybe not hobby farming , they have weight that is well suited for plowing and or disking large acreage , they still go for a mint around here for row crop farming.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #8
Bob
If I remember correctly some of those models the blocks can be turned and bolted back up making the lift arms come in more, other words they have holes both ways, one way is wider and your picture isn't real clear but it looks like that is how yours are bolted on, check it out and see if those blocks have holes the other way.
   / How to attach Cat 2 mower to Cat 3 on John Deere 4630 tractor #9
We have no idea what size flail the op has. With a well adjusted slip clutch or shear bolt why should this be a problem. Should have no problems bogging down is heavy/tall grass or brush.
BTW - nice tractor.
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
Adams 8 Ton Weigh Hopper (A55314)
Adams 8 Ton Weigh...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
