Kubota Mower Deck Pulley Failure
/ Kubota Mower Deck Pulley Failure #1
jkahan
Hi folks - hope this question is not too far out there.
I have a Kubota ZD1211-60 diesel zero turn mower -- awesome btw - I use it to mow about 10 acres of lawns and fields (bumpy but fun). Yesterday, one of the deck side pullies (drive belt contact point for one of the 3 blades) literally disappeared. the whole thing is MIA except for the core hub (where the blade spindle attaches). The pulley must have gotten wicked hot since it it melted the protective plastic deck cover. Belt appears to be fine. Anyone else seen this before? bad pulley's diameter is 3" (+/-). Good pulley has a 6 3/4" diameter.
here's what a good pulley looks like -- what the heck happened? alien abduction?
thing was running up until it suddenly stopped cutting (and it was obvious because I was cutting fairly tall field grass). Good pulley's diameter is 6 3/4".
/ Kubota Mower Deck Pulley Failure #3
What does the spindle feel like? Bearings shot? Locked up?
Looks like a two piece pulley that split and only left the lower half?
/ Kubota Mower Deck Pulley Failure #4
Tractor supply has pulleys and yes the cheap china
made pulleys will separate!
willy
/ Kubota Mower Deck Pulley Failure #5
The nut (with the grease fitting) that holds the pulley onto the spindle is gone.
But which came first? Did pulley disintegrate, releasing tension on nut, nut fly off, followed by pulley? Seems like mowing would of stopped and noises would of been heard before nut came off.
Or did nut come off on it’s own, allowing pulley to spin (instead of locked) on spindle shaft and destroy itself?
Are spindle bearings gone and heating effects found weak link and destroyed pulley?
Did you find remains of pulley? Or nut?
It might be best to replace the whole spindle if you got it apart rather than chasing problems with partial replacement. Depends on how you value dollars vs time.
/ Kubota Mower Deck Pulley Failure #6
I am not familiar with ZD1211-60 mower, but could it be that mowing 10 acres of lawns and fields with "fairy tall field grass" is asking bit too much of this type of mower in the long run?
/ Kubota Mower Deck Pulley Failure #7
I was thinking the same thing.
thank you everyone for your replies and my sincere apologies for not thanking you sooner.
As someone noted above, the outside part of the pulley and the inside hub of the pulley broke apart. Spindle is in good shape.
Besides the $80 price tag, the pulley replacement is easy - it's getting that deck out and lifted up to play with the blades and service the whole unit that's a bear.
I broke a pulley a couple of years ago as well (didn't record if it was the same side though).
I am using the mower to mow both lawns, and lumpy fields; this might explain the excessive wear, vibrations, etc...
Anycase, thanks all and again, sorry to drop out of my own thread; really appreciate the help.
--josh
I did find the remains of the pulley -- intact. spindle and bearings were fine (plenty of grease)
really appreciated your help; thanks and again sorry for the long delay in responding.
/ Kubota Mower Deck Pulley Failure #10
I wouldnt think mowing tall grass with a 24hp diesel zero turn would be to much to ask. If it was I would expect the belts to be wearing out...this looks like the pully contact something and rolled it over.
/ Kubota Mower Deck Pulley Failure #11
Looks like the pulley said HELLO MR ROCK OUCH!
$80 pulleys don't cost that much at Tractor Supply
The bearings are sealed so a grease fitting does not
put grease in bearing, you need to remove the shield
on one side of the bearing and then grease it good and
put the open side towards the center to keep dirt out
by doing this bearings will last a lot longer
willy
/ Kubota Mower Deck Pulley Failure #12
Here's what I am saying:
In my opinion a mowers with deck pulleys like this (and sealed bearing spindles) were probably not meant for regular mowing acres of fields with fairly tall grass.
ZD1211 is a fine mower no doubt but meant primarily for maintaining established lawns.
This would be a big step in the right direction, but it's still meant primarily for established lawns, just more hours of use:
/ Kubota Mower Deck Pulley Failure #13
Theres a grease fitting right in the pic of the "sealed bearing" spindle.
/ Kubota Mower Deck Pulley Failure #14
Yes that's pretty funny, realized that from an earlier post - the photo in post #12 with the cast iron pulley is different though.
Conical roller bearings, the exact same as 2000# trailer axle bearings, but it's still meant & designed to be a lawn mower.
/ Kubota Mower Deck Pulley Failure #15
On the spindles of riding lawn mowers with grease
fittings on the spindles how does the grease get into
the sealed bearings????? The bearings are SEALED???
willy
/ Kubota Mower Deck Pulley Failure #16
I'm still failing to see how a rolled over pully because it looks like it's been rubbing against something would benefit from grease in a bearing.
A stronger pully wouldnt even help because nothing should be touching the pully becids the belt.
/ Kubota Mower Deck Pulley Failure #17
Grease or no grease has nothing to do with the pulley unless lack of grease locked up the spindle. The op said it wasn't the case here as spindle was still free and tight.
Regarding the grease/sealed bearing discussion that this post has turned into.... If it has a grease fitting it is not a sealed bearing. The inboard seals are not there. Only the outboard seals remain to contain the grease AND prevent water from getting in.
There were "some" low end mowers that had greasable spindles....and upon a spindle failure the owner would disassemble only to find double sealed bearings. So no amount of grease in the spindle zerk would get to the bearing.
Most manufactures of mowers offer both spindles that are greasable and ones that aren't. Usually the non-greasable stuff is homeowner stuff. But I cannot help but thin the MFG's have both double sealed bearings as well as bearings with only a single seal in their inventory.
So was it an oversight on a manufacture, did an employee grab a wrong bearing, was it intentional? Who knows. But it is NOT the norm in most mowers. Most mowers that don't have a zerk are sealed bearing. Most that do have no inner seal so the grease actually does go to the bearing.
/ Kubota Mower Deck Pulley Failure #18
I have seen both with a zerk and without and the bearings
are sealed both sides why? have no idea
willy
/ Kubota Mower Deck Pulley Failure #19
willy
Probably a manufacture oversight like I said.
Take toro for example. They have spindles that have zerks and ones that dont. But the spindles are the SAME. Bearings are the same size. So someone maybe put the wrong combination together.
Either way though....if the bearings are indeed sealed on both sides, Id still rather have the zerk. Wont do any good initially. But the first time you rebuild the spindle, put bearings in with only one seal...now the grease is actually getting to the bearing. Simply rebuilding with the correct bearings is a whole lot easier than trying to modify a spindle to accept a grease fitting.
/ Kubota Mower Deck Pulley Failure #20
After 12 years of mowing my 60" Kubota deck had a similar problem. The Top nut on the shaft would not stay on. No amount of tightening, new top nuts/lock washers or lock tight paint would keep it from working loose. I found that the hex shaped shaft that the pulley sits on was worn down plus the pulley hex center was enlarged causing a lot of play between those two parts. New shafts, pulley, bearings and grease seals have given me another 8 years of service no problems. I bought the BX2200 in august of 2001 it has 2710 hrs. on it. The belt is still the original one but I keep a close eye on it. Hope this helps and good luck.
15K PARTEK TRIPLEX PUMP (SHOP BUILT NONE TITLED) (A63569)
15K PARTEK TRIPLEX...
Ford F-450 (A63118)
Ford F-450 (A63118)
3012SFL (A61567)
3012SFL (A61567)
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59910)
2020 INTERNATIONAL...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
