Used Value vs Age
/ Used Value vs Age #182
The "best of both worlds" is having a relatively modern, pre tier-4 tractor for most of the work, and an old, easily serviced, good parts availability one for backup. That's what I do with my 2005, John Deere 4120, and 1951 Ford 8n. For the last 16 years, there has never been a job I couldn't get done because my tractor(s) were broken down.
With that pair, I dont suppose there will ever be a need for me to purchase a post tier-4 tractor. Certainly their efficiency is still lagging that of the JD 4120.
I remember back when the tractor manufacturers were scrambling to get tier 4’s out the door in about 2013. Coincidentally I was looking for another new (highly efficient) 130HP tractor. Was looking at Kubota, NH, MF and Case-IH.
Every tier 4 tractor that year also seemed to have a newer, updated cab and other improvements. I distinctly remember the newer M126“G” had a nicer cab and buddy seat and a 24 speed transmission. It was more expensive, too. Dealer had a “leftover” 2012 M126x and made me a great offer which I took. Still have it.
Looking back on it, I wonder why manufacturers had to make substantial improvements to those tier 4 tractors in the first year they came out? I bet it was to help customers decision to buy on new unproven technology (tier 4 dpf) a little ”easier”.
/ Used Value vs Age #183
I'll be that was the case too!
/ Used Value vs Age #186
My 1965 Nova weighs in at 2,910lbs. That’s with a 383 stroker V-8 and no back seat.
Maybe you're meaning a 396? My 1968 Dart GTS, stock, had a 383: I replaced that with a 440 (because I was a kid).
/ Used Value vs Age #187
I don’t like tuning carburetors and I’ve never been good at it. That sounds like 6 times the headache. My dad’s 47 Ford pickup had dual 2 barrels on a 90ci flathead that ran amazing and looked really cool. I remember him using a string of vacuum gauges hanging from the hood to tune the carbs.
I did something similar on dual side-draft SU carbs on an old Volvo I once owned. I could make that thing run smoother than any engine.
/ Used Value vs Age #188
The king-of-the-hill pursuit by many manufacturers as pertains to power relies heavily on computer operation. I have computer-controlled engines in my VW TDIs and in my Kioti. I've had none in my diesel trucks: I've attempted to get one that did, but I couldn't justify the cost- and I'm talking used! Cannot even start to compare the power outputs between my 94 Dodge Cummins 5.9L and a new Ram Cummins 6.7L (although a larger displacement, the per-litre output is more than twice that of the 1994; enough said on the torque numbers). My cars have been flawless, and they're 18 and 21 years old; both are benefiting from computer tweaks that bump power, something that you're not going to be able to do with a non-computer controlled engine (without a lot more cost): yeah, I could have left them stock, but we're talking 90hp! Only 675 hrs and 5 years on my Kioti and not a single engine or computer issue (<knocks on forehead!>); time will tell.
In all this mix, and not mentioned yet in this thread (if so, then sorry I'm forgetting/missed), is changes to the fuel. While old and new engines alike have to run it, my point here is the evolution/change took place for valid reasons (reduction of sulfur in diesel; reductino of lead in gasoline). Interesting/fair article here:
Ultra Low Sulfur Diesel (ULSD): the Good, the Bad, and the Rusty
Reduction in sulfur dioxide IS a good thing vis a vis health, if, that is, we're less taking less-than full accounting: again, as I noted in a previous post, we're far from being able to make a full accounting of impacts; that does not, however, mean we should dismiss things in a "ah ha! we cannot prove it so why bother doing it" manner; lots of times we are aiming in the right direction, meaning it's the right path/idea, but we're not shooting with the correct trajectory- that's pretty much been the history of humans.
At one point the world was going to end when fuel injection came on to the scene... I'll refrain from pointing out (well, not really) that fuel injection results in the sale of a lot of chemicals (for cleaning fuel injectors and other gummed up stuff). I cannot feign certainty in ANY direction (other than knowing that perpetual growth on a finite planet is mathmatically impossible, yet we base our entire economic system on that premise). I ain't pushing anything. I just do with, or try to do with, what I have. I'd have no broad brushes in my tool box...
/ Used Value vs Age #189
I took the original sbc 327 ,13:1 compression ratio, to the machine shop for a complete rebuild. They explained to me how the 383 with 9:1 compression ratio was going to make more power, double the fuel economy and last 4 times longer than the 327. They took a 350 small block and modified it to fit a 400 small block crankshaft, increasing the piston stroke inside the cylinder which increases the cubic inches from 350 to 383. There are several other performance mods but that’s the basics of it. This was all at the same cost of rebuilding the 327 to the original specs it was at to produce 375 HP. The 383 produces 420 HP. I didn’t care about the car being original so this was a no brainer decision for me.
Yeah, not a factory displacement spec. I knew there were a lot of odd ones that floated out there but I don't recall GM ever producing a displacement of this size. Dodge produced some GTS Darts with 428 hemis in them, 50 I think. Getting power down to the ground starts to become problematic! I liked big blocks, but as the years progressed I got into smaller and smaller engines, settling on my mildly tuned 1.9L TDIs (fun to drive; AND, I can get over 800 miles on a tank of fuel).
/ Used Value vs Age #190
"We need to do all we can to slow climate change and cut emissions"
Do the Chinese, Indians, Russians, etc. feel this way too, or if just "we" do it, the problem will be solved?
The others don't give a hoot about what "we" do!
and there's a new round coming in 2027. 'The Western Producer': that will add $58,000 to the cost of a heavy-duty truck. An extra SCV, double DEF, electric exhaust heater, cylinder de-activation. And if any of these things are on the fritz, you're just standing there.
/ Used Value vs Age #191
Of course, the Chinese, Russians, Indians, etc. will all be doing the same, as they are just standing by to follow the USA lead!
/ Used Value vs Age #194
Got a link ?
/ Used Value vs Age #195
What vehicles have gotten lighter in subsequent generations?
Again, no hard data, but I can't imagine that a 350/3500 dually with a metal bed would weigh less than a newer model with fiberglass bed. I was actually shocked & even a bit angry when I saw a fairly new dually that had a broken fiberglass bed from the filler tube back through the wheel wells and all the way back to the gate. Guess my next dually will be without a bed - hopefully my '82 will out live me! 😉🙃🙂
/ Used Value vs Age #196
The Chinese are moving towards an electric motive system faster than the USA, where the oil companies are doing their best to prevent it.
Most tractors under 100 hp that use diesel fuel will be obsolete in ten years anyway, when it all goes electric, even in the backward US of A.
I'm just too old to wait around for it.
So that's why they are building so many coal fired plants? But I'm sure they are making "soot free" coal over there, right?
/ Used Value vs Age #197
Gotta collect enough taxes to pay for imperialism (to force others to be part of the "free market").
/ Used Value vs Age #198
A new round of what? Got a link?
/ Used Value vs Age #199
In 15 years or so, I won't be around to see it, but all the new sub-100hp tractors will be electric, and they will be relatively cheap compared to what we pay for new diesels now.
On cars, the original complicated and fuel mileage robbing stuff from the early anti-pollution stuff is long gone now, and in a few more years, say 20 or so, everything will be EVs anyway.
Like it or not, there are a lot of small tractors out there. I see them almost every time I go anywhere. The one dealer lot that had a ton of tractors this spring among the ones in the area that I visited was the MF dealer, who had a very full lot. That lot is almost empty now. The other ones have pretty much been almost empty right through.
In a world, of soon to be 8 Billion people and still growing, The internal combustion engine, along with all that fancy pollution stuff is already obsolete, and with good reason.
The gas pump is going the way of the iceman and the whale oil business.
/ Used Value vs Age #200
I'm still waiting for my flying car that I was supposed to get 30 years ago.
