Opinions on which tractor I should sell
   / Opinions on which tractor I should sell #11
I had the same problem as you, at the old house I had a Branson 4520R with 45 hrs on it, at the new house 4000 miles away I had a Branson 5520cab with 20 hrs on it.
I brought the 4520 to the new house and decided to keep them both! I use the cab for mowing and the 4520 for loader work.
It works for me and there's room in the shop for both.
   / Opinions on which tractor I should sell #12
I would keep the 5740 if you have had the trans and 4 wheel dive shafts seals replaced. If not then comes the big ??, take a chance that the 40 well not get a leak or keep the newer 60 and hope that kubota got that taken care of after the 40's. ???????
   / Opinions on which tractor I should sell #13
Sell both and buy a Compact Telehandler with a SSQA: Compact telehandler and V519 Compact Telehandler
I went back and read all the threads on these things. I was finally sold when I saw the bush hog mounted on the front. I've seen these on construction sites but had no idea how useful they would be for my applications. I've been shopping/thinking about a larger tractor because I need more lift. These things seem to do it all plus it would allow me to get to the upper hay storage areas with large bales so I wouldn't have to move small bales by hand.
There's a bobcat and JCB dealer close to my house, I'm going to make a trip over there. It looks like JCB makes one smaller than the bobcat 417, that would fit my needs a little better and be more friendly to the pasture and grass. Thanks for posting this.
   / Opinions on which tractor I should sell #14
You have seen full size telehandlers on construction sites.
I think the smaller JCBs come with SSQA, if not adapters are available.
2020 DRAGON ESP...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
