WoodMax SB-60 Rear PTO Snow Blower on Gravel Report
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #1
KennK
NE Wisconsin
John Deere 3320
Last fall I purchased a WoodMax SB-60 rear PTO snow blower for use on my John Deere 3320 for use on my 600 feet of of gravel driveway in northern Wisconsin. Our snowfall over the past few winters was 61, 49, 53, 83, 96, and 73 inches (oddly, this winter we've only had 17 inches so far as we approach the end of January).
After the first snow accumulation I drove up/down the gravel drive with my pickup to pack down a base, and then when we got the next few inches of snow I had my first chance at using the snow blower. It didn't go well - the skid pads started digging through the base - likely because the initial base was not thick enough. The only way I could blow snow was the let the blower hang (skids in the air) and manually control the height to minimize touching gravel. It didn't go well.
We let the next few small snows accumulate, and finally on a somewhat warmer day (mid 20's F) used the pickup to pack down another base. This base looked much nicer - thicker.
Last weekend we had about 3-1/2 inches of snow. With some apprehension I headed out again with the snow blower. This time it worked amazingly well!! The skids floated along the base as I'd hoped, and there was no digging down to the gravel. Because the tractor has a hydrostatic transmission (not sure if that's the right word) the forward/backward pedals are on the right side, as are the PTO arm lift and chute rotation controls, so I had to rotate my body/neck to the right side. I found it best to start on the right side since I had the best view of that corner I could better gauge my location. I cleared the entire 600 foot length, drove back to the starting place, and was able to see the left cleared edge, and did it again. Three passes and the driveway was done.
I had the skids on the as-shipped height, which is less than 1 inch high. I'd flipped the cutting edge over as suggested in the WoodMax manual. I put the diamond type tire chains on the rear tires. Boy do they buck as I drive along!! I should have purchased the Euro-type. I'll get them at some point.
I have to say that I'm somewhat surprised by how quiet the snow blower is. It has a nice soft rhythmic sound that gets slightly louder as it enters heavier snow - like the stuff off the road plow.
When I was done I was a bit covered with snow, but oddly my glasses were pretty clear, and my 60+ year old arthritic neck was OK. I think the breaks driving back to the starting point helped with that.
When done I parked the snow blower in the sunshine while I used a broom and the clearing tool to clean it up. The sun helped a lot. I found that there enough play in the PTO driveline that before starting the tractor I can rotate the auger a bit to be sure that it is not frozen - just to be sure I don't shear a bolt for that reason.
Oh, one last thing ... I was concerned about how to lube the drive chain. I ended up using WD 40's Chain Lube spray (love their folding tubes!!), and I had my wife sit on the running tractor, apply the parking brake, raise the snow blower a bit, and turn on the PTO driveline. There is a small opening above the chain toward the front, and I was able to carefully stand to the side of the snow blower and spray both the top and bottom "layers" of chain as it rotates. It actually felt pretty safe - I made sure nothing was hanging down (hoodie ties ...).
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #2
It sounds like you did good.
On the base, keep in mind that it isn't just having a base that is important, it is having the ground frozen underneath that base. I usually use my ATV to clear the first few minor storms so the snow isn't insulating the ground from freezing. Once the ground is frozen, the tractor comes out.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #3
Have the same problem with my SB-60 on gravel and have been trying to figure out a DIY better skid shoe to keep from digging in the gravel drive. Haven't discovered any other solution than packing drive down with the pickup for the first few snows to create a solid (frozen) base as you noted. The SB-60 moves a lot of snow and is quiet, well built. So far I have just greased the chain before the season and haven't detected a problem. It gets a little getting use to having to turn around on the seat to navigate going backwards.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #4
If you go to a welding shop they can make a large wide ski from strap steel that is longer than the snow blowers length and then
curve up on both ends of the skis and then you can avoid digging in the driveway.
They would have to make a new mount for the snow blower if the original steel is too thin to weld OR if they are made from cast iron.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #5
I modified the optional skids that Land Pride offered for my SB1574 Snow Blower, they work slicker than snot on a rake handle on my gravel drive. Phone pics 093.jpg
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #6
About lubing the chain, after lots of trial and error on what sticks the best to the chain? I tried WD40, m/c chain lube, ACF-50........I concluded good old fashion 80w90 gear ol dispensed while snowblower was running at idle from the bottle worked REALLY good.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #7
I was thinking about replacing skids with hard rubber wheels. Anybody done that?
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #8
I just got a SS-60 (olver version of the SB-60) I have yet to use it but from years of plowing gravel driveways you dont ever want the plow to touch the gravel. Until you have 2in of compacted snow/ice leave the plow up. This is what I plan to do with my blower also.
I have tried skids on gravel plowing and they seem to just dig in and destroy the driveway.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #9
Good point about the frozen ground. I also use my ATV for the first few snowfalls, and it also helps to pack the snow. Then outcomes my rear mount snowblower on my BX25.
   / WoodMax SB-60 Rear PTO Snow Blower on Gravel Report #10
I replaced skids with 6 inch hard rubber tires from Tractor Supply. Worked good for me. Leaves about 2-2.5 inches from the ground
John Deere 825i Gator (A50514)
John Deere 825i...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
