B29 Overheard
/ B29 Overheard
North of Day, west of Bittersweet. Two 2000' runways running NW-NE and SE-NW.
/ B29 Overheard
I swear i could even smell the exhaust from the startup.
You know you got something when you need people manning fire extinguishers on startup. 😬
I've seen that on a lot of old radials.
I got to ride in a Beech 18 from here over to Chicago and back one night. Freighter. Loud in that one.
/ B29 Overheard #34
No it wasn't the midway airport. That's down by Dunlap, between Elkhart and Goshen. I used to drive by that daily. There was an Ericoupe tied down there. The one I'm talking about was between Mishawaka and Elkhart, on Day Road.
Okay, yes that was Sportsman airport. One of the hangars was still there 10 or 15 years ago before they started building houses along that area of Day Road.
/ B29 Overheard #35
There was a Beech 18 that an museum organization at Goshen Airport owned a while back, I did some avionics work up in the nose, behind the panel, that was fun getting my big ass stuffed in there. A couple of days later, I got to set in the right seat on a test flight to see if my rewire job worked. Even with foam earplugs and and ANR headset, it was still loud in there. Of course you're setting just behind the arc of the props.
Someone at Goshen just recently bought an 18 and was doing takeoffs and landings for a couple of hours one afternoon when I was at my hangar. Good thing avgas is only $4.60 a gallon.
/ B29 Overheard
Here's a pic from an old TOPO map that shows it.
/ B29 Overheard
And Midway was not a place you wanted to be on Palm Sunday, 1965...
/ B29 Overheard #40
We have an annual small air show in my town. Same guys bring their warbirds out and fly them around. Absolutely fascinated with the WW-II Vought Corsair fighter. It has an enormous radial engine that sounds incredible.
The pilot flies it overhead like ~200 ft over your head, nice & slow and the sound of the radial engine literally thumps your chest. He will do a few of the fly overs, then mash the stick, pick up speed and climb over the tree line.
Doesn’t sound amazing the way I’m describing, but to be there and see it in its Marine Corps paint fly low over you with a 2000HP radial engine is something I can’t describe.
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2017 Nissan Quest Van (A61569)
2017 Nissan Quest...
2019 JCB 457 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2018 FREIGHTLINER...
