Parts problems
/ Parts problems #1
rjwerth
Gold Member
Outside of Detroit, MI
DK50SE Cab
Is anyone having problems getting parts for their Kioti? I have a 2012 DK50SE and it seems that Kioti is no longer making the cooling line between the HST filter and the cooler. The only part they offer must be modified to fit. By modified, I mean you actually have to grind off a support and weld it on elsewhere. This is after 2 attempts over 2 months to get the right part.
This makes me very unhappy. How is it I can no longer just buy a part that just fits?? If this is how Kioti is doing business these days, I would consider this a big red flag for those looking to buy a new tractor.
FYI: the dealer I'm working with is very well known in this circle so the problem seems to be with Kioti.
/ Parts problems #2
Similar issues for my DK55. Best I can do is order similar pivot pins (for kl1595 loader) and take to machine shop to be modified.
/ Parts problems #3
You might try sourcing your parts from Bobcat. the DK50SE is also a Bobcat CT450. I just did a bunch of engine work on mine and the longest it took to get a part was 4 days. And there was a bunch of weird stuff... One note. If you try to order parts online, it says the parts are not found or available. It's just that they don't have the catalog loaded for their online store. Just call a dealer with your p/n's and they can verify what's on hand at the warehouse. Click link below to access the catalog to look up p/n's.
bobcatpartsonline.com
/ Parts problems #4
Parts for machines is a huge problem in covid era. Not restricted to Kioti for sure, not that that solves the OP's issue...
/ Parts problems #5
I waited 2 months for a front diff seal for an lk3054. There were none in the country pre COVID. I had aIways struggled to gory parts for this machine and a month waiting for parts was common. I took it apart and put a couple o rings in cleaned the oil off put it at the road and sold it for more than I paid for and replaced it with a real orange tractor
/ Parts problems #6
so you are saying not even a bearing and seal dealer could match the seal?
/ Parts problems #7
No I work on industrial equipment and none of my bearing and hydraulic suppliers could duplicate it it was flanged and tapered at odd angles and an odd size the closest we came was a hydraulic cylinder seal but it wasn’t tapered enough to fit
/ Parts problems #8
I just pulled up a Mahindra 2540 tractor for sale on a tractor listing website. It's been repaired under warranty and sitting at a dealer on consignment. The owner says it sat for past year waiting on parts and he's not laid eyes on it for over a year. He bought another tractor and now selling it. Mines only been down ~3 months-I'm losing track of the dates.
I think I might have called a seal manufacturer in that senario? Not tryin to second guess your repair, just a thought.
/ Parts problems #9
Been waiting on a $6 part of a new out of box never run pressure washer for almost a year. Currently have camshaft for the Briggs single cylinder OHV on backorder, one since April. There is over a thousand of those camshafts on backorder nationwide, and those represent mowers sitting on dealer lots waiting for repair. Been waiting on a replacement carb for a customers leaf vacuum since March. ETA as of right now is September, but I don't believe it will show up either.
/ Parts problems #10
Two of my nephews haul truck loads of vehicle parts in/out of the Louisville, KY area. It's been erratic for a long time now and some busy weeks with daily hauls and others with layoffs.
/ Parts problems #11
I have a BobCat CT450 and have the opposite issue. Bobcat isn't interested in getting parts so I used your reference to the Kioti DK50SE and found essentially identical parts diagrams and reference numbers for the right cab door and front grill assembly, both of which are damaged on the used one I just bought. Kioti has them, Bobcat tells me at least one of the grill components is no longer made. BobCat can't guess at the door glass delivery, Kioti has them in stock. The Kioti parts guy at my local dealership cautioned me that the BobCat CT450 isn't necessarily a patched over/white Kioti DK50SE, but they sure look the same, even the bonnet lines and shapes of grill pieces, so I took a $1800 chance (Canadian). I would like to confirm that my tractor (S/N ABHM11599, engine No. 800328, 09/10/15 (that is year/month/day, correct?) will take the filters with Kioti part numbers for the DK50SE. I don't see why not but saw a reference to potentially different engines. I can't actually find a table with BobCat part numbers beside their equivalent Kioti part numbers for oil filters and hydraulic fluid and hydrostatic filters in my searching, though the hydrostatic filters converge via other aftermarket brands like Baldwin and Wixx. Care to weigh in?
/ Parts problems #12
Have you tried figuring it out using a Baldwin or Wix site. I took the filters, for my TYM, blew them down with a couple of cans of brake cleaner to get the oil and crud, off and out.
Then went to the local NAPA, and and with a set of calipers we cross referenced them to some Wix filters. If you decide to try that, go in Wednesday or Thursday between 1330 and 1500, when they have a bit of slack time. It will take some time, and they really don’t have it during the busy periods.
I will admit my local NAPA is in a very remote, rural place, with a lot of people trying to keep a large assortment of strange stuff working, from farm implements and tractors, to old mining equipment, and small saw mills. So, they are a lot more flexible, than the ones in small towns.
/ Parts problems #13
Thanks. I did some more sleuthing last night and after a few cross match attempts, am now sure of what I need. Reading the thread was really helpful.
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
