Recommendations for mold killing/resistant paint please
/ Recommendations for mold killing/resistant paint please #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
This is for a cool damp basement in northeast Mississippi. It's got cement block walls covered by rough sawn lumber. We run a dehumidifier. I've primed the walls with Zinnser/Rustoleum Mold Killing Primer.
Looking to put a coat or two of an off white or light color on it but don't want to battle mold. Saw M-1 Advanced Mildew Treatment on Sherwin Williams website. Thought I'd ask the TBN crowd what they would recommend.
/ Recommendations for mold killing/resistant paint please #2
Once you have mold on boards, it is tough. I suspect that you will continue to have damp come through the walls. Any moisture will feed the mold and it will grow through paint. Sorry.
That said, any mildew resistant paint will help. Depending on your local regulations you may be able to buy fungicide paint additive. I would also use a gloss paint to help shed any condensation and to be able to clean it better in the future. (TSP and bleach)
All the best,
Peter
/ Recommendations for mold killing/resistant paint please #3
Remove the wood.
Seal the block
Leave the wood off.
/ Recommendations for mold killing/resistant paint please #4
We have used the SW product with great results here in SW Virginia. Inside and out.
/ Recommendations for mold killing/resistant paint please #5
If you've not yet primed the wood you can try spraying with a ten percent solution of household bleach, vinegar, or Listerine. If you then seal and prime the wood it should be fine. Unfortunately you may still have mold already infesting that concrete wall. As far as paint, there are mold resisting additives for latex paint or you can just thin the paint a bit with bleach.
/ Recommendations for mold killing/resistant paint please #6
Bleach dosnt kill mold in porous surfaces. White vinegar does though.
/ Recommendations for mold killing/resistant paint please #7
Ask at a paint store. They sell additives for any latex paint that will do what you want.
/ Recommendations for mold killing/resistant paint please #8
Sure wish I knew of that additive.
I completely sanded/scraped my wood exterior* and applied 2 coats of opaque stain 3 years ago.
He11 of a job and it looked great.
But no longer!
Looks like it has measles or a variant of Covid.
I'm not alone as I have noted many properties that demonstrate an 'infected' outer finish.
I suspect it is due to the new (regional) water based finishes that were marketed a bit too fast without adequate testing.
So what to do now?
Pressure wash with biocides? re finish ?($$)
/ Recommendations for mold killing/resistant paint please #9
@PILOON Sorry to hear it. Once fungus is in paint, it will grow through. It will grow through latex faster than oil based paints/stains. If it is algae, you can clean it off, but it will also regrow. One downside to stains is that they aren't as smooth as paint and tend to trap dust, which becomes a growing site for mold/algae.
Try pressure washing with a house cleaner that mentions mold or algae. Do you know if it is algae vs mold? There is also cleaning with a mixture of TSP and bleach, but check that your stain can handle bleach.
All the best, Peter
/ Recommendations for mold killing/resistant paint please #10
When I was trying to repaint a wall in a bathroom that was covered with wall paper, I was advised to clean it, use Zinnser or similar. But let it set for a week to fully cure. Then to paint it. The can directions said ok to paint after a few hours, but does not say anything about full cure would take a week. So that's what I did. Jon
/ Recommendations for mold killing/resistant paint please #11
If you are getting mold on the wood it needs cleaned and sealed. But first you need to seal the block, as that is where the moisture Is coming through. A couple products seal krete but better is ugl drylok. The regular holds back 4psi, but the extreme holds back like 15psi. Also a vapor barrier between the wood and block will help. Also think about how the moisture is getting there, grading the area around the basement, extend your downspouts etc.
/ Recommendations for mold killing/resistant paint please #12
Just a thought. I had new shingles installed on the house about ten years ago. They were GUARANTEED to prevent mold, mildew and fungus. Not that we ever have enough moisture here to worry about such things.
However - the reason for this fantastic claim - there is copper infused into the shingles. I wonder if this could hold true for some forms of coatings also.
I know that many paint products used on the hulls of ships are also copper based.
/ Recommendations for mold killing/resistant paint please #13
If the walls are continually damp behind the wood sealing the indoor surface is just going to trap more moisture between them. The dehumidifier won't do its best without air circulation. Controlling runoff is indeed the first step in drying below grade spaces.
I'd pull the paneling, etch, seal, and paint the masonry. Trouble areas would be obvious vs hidden and easier to touch up if/as needed.
/ Recommendations for mold killing/resistant paint please #14
I have also noticed that I'm not alone as many light colored opaque stained buildings sport that spotty mold that I referred to in earlier post.
They mostly were north facing sides.
The sun seems to handle that mold problem OK, but in my case I'm very shaded.
/ Recommendations for mold killing/resistant paint please #15
Yes, that was the point I was trying to make about stain and surfaces. Stain leaves a rougher finish that traps dirt and water better, so you are going to have more dirt / algae / mold issues with stain compared to paint, and in the northern hemisphere, it will be worst on the north facing sides. It isn't you, it is the nature of north facing walls and paint vs. stain.
All the best,
Peter
/ Recommendations for mold killing/resistant paint please #16
I was under the impression that the copper in paint was to prevent barnacles from growing on the hulls of ships/boats.
Shingles have micro granular metallic zinc (and some use copper or copper & zinc) as an anti mold/mildew ingredient and there are alsp strips of metallic zinc that are designed to be installed at the ridge to help stop mold/mildew.
