Bucket cylinder bent rod
/ Bucket cylinder bent rod #1
Unclewilley
East Aurora
Massey Furgeson
I have a Massey Ferguson 1742 tractor with DL125 FEL. Bent the cylinder rod in one of a FEL bucket cylinders (AGAIN!!!). The bucket cylinder was previously replaced by a dealer using an ACGO part # AL60006622 ($1,174 - part $835, labor $245 plus tax). The replacement cylinder was not an exact replacement but did fit. Not sure I'm up to trying to replace the cylinder rod??
Any recommendations regarding non-oem cylinders?
Any help appreciated!!!
/ Bucket cylinder bent rod #2
It's a pretty safe bet somebody built that loader for Massey. Quicke, Ansung, KMW, somebody. Find out who and you might knock 50% off your cost. Or see if you have a good hydraulics shop anywhere near you. If so they can build/fix/supply what you need from a new rod and seal kit to a complete cylinder.
Bailey Hydraulics, Baum Iron and Surplus Center are worth checking for generic cylinders.
$245 labor to change one loader cylinder? Did you go to the hospital and get a rape kit afterwards?
/ Bucket cylinder bent rod #3
Speaking of getting shafted, that $835 for the cylinder is no bargain either. Especially for an after market part. I just paid less than half that for four cylinders at Surplus Center for my Kubota. o_O
I sure hope they used corn head grease of something. 😏
/ Bucket cylinder bent rod #4
Ditto on the above recommendation about a hydraulics shop. I had a badly bent cylinder rod on a backhoe boom. A local shop straightened it for me. I'm sure it was less than $200 for them to get it lined back up and it's a simple 10 minute job to remove and install. This also included new seals on the shaft end because I had wallowed that out a bit trying to use it bent.
/ Bucket cylinder bent rod #6
After you get it fixed....you need to figure out what your are doing wrong to bend the cylinders and not do it again
99 percent chance he’s back dragging with the bucket beyond 45 degrees.
/ Bucket cylinder bent rod #8
Or using forks......
Dave M7040
Back-dragging or prying with forks. There’s not a lot of potential to bend rods using forks for lifting. It sounds like the OP needs a CTL and stop using the tractor as one.
/ Bucket cylinder bent rod #9
Or - learning that a tractor is not a bull dozer. Expensive lesson...........
/ Bucket cylinder bent rod #11
My god man they see you coming before you even got out of your drive way.
Thanks for the reply.
Based on replies to my it seems clear I need to get remedial training on how NOT to use my tractor/bucket!! 😳😳 I've been clearing a section of woods, 1st screw up was lifting a log and rolling bucket too far. Log rolled on cylinder rod, bent, my bad!! Latest problem, yes I was abusing the bucket, dragging on brush, small trees. Although apparently a "no-no", the original bucker cylinder was fine, it's the new one that bent. The new cylinder is also from the mfg (AGCO) but not exactly the same as the original on the loader.
I'm trying to find a hydraulic shop. Regarding suggesting purchase of aftermarket cylinder, what are opinions of Surpluscenter.com and Magister Hydraulics? Any other aftermarket equipment recommended?
Thanks again!!!!
/ Bucket cylinder bent rod #14
I had a cylinder straightened on a 480 Case and the first time it was used to lift a new bucket for a 330 Cat excavator the straightened rod bent in the same place and the other cylinder gave out about 10 seconds later.
/ Bucket cylinder bent rod #15
Thanks again!!!!
Well, here is the deal, the log rolling over on and bending the cylinder was kind of a freak accident thing, You know now not to do that. And besides a grapple is the proper tool to be picking up logs with. Yeah, I know, you don't have one, but you could have nearly bought one for the price of that cylinder replacement.
As for the back dragging of brush, you now know you got to be really careful doing that, you can get away with it USUALLY, but sometimes if you roll the bucket down too much and you make the bucket so that it won't slip over an immovable object then you know that a bent cylinder ram or even both of them is a possibility. Don't do that no more.
You can use the float position on your joystick allow the bucket to float over the terrain with just the weight of the bucket and the loader arms as the down force. This allows the bucket to float up over something immovable if you hit it. If you don't understand about float, ask some more questions.
As for back-dragging over even small trees, that is never going to have a good outcome. Tractors are amazingly tough, BUT there are some just "silly" things you can do to tear them up. Now you have been there/done that, so don't do that no more.
Yep, lessons learned the "hard way"!!!
Any thoughts re buying non-OEM parts? I'm sure some are better than others!!! If there is a "heavier duty" that "fits", that would be my preference! Apparently the mfgs "hide" specs on parts trying to get you to purchase OEM. Gave up trying to find part # / specs on the original bucker cylinder. Guess I need to take some measurements of the remaining original cylinder and look for a match. Assuming I find a match (close as possible) would it be best to replace both cylinders so both are exactly the same??
/ Bucket cylinder bent rod #17
Well, the facts are with my 30 years and 5 different tractor experience, I have never bent a cylinder rod. There for I am no "authority" on replacing cylinders. I do have no doubts that you could have found 2 aftermarket cylinders and replaced them yourself for less money than you paid to have the single cylinder replaced for. Remember also that there are plenty of places that rebuild cylinders for a lot less money. The $200 + for replacement labor was just asinine.
/ Bucket cylinder bent rod #18
This happened to me a few years back. My cylinder bent almost 45 degrees. Took it in and had it repaired for $500.00, only to find out that I could buy a brand new one for $600.00.. I was digging a French drain with a stump bucket and then dragging the trench in high 1st gear with no problem. The tractor would start to bog down giving me the time to back off. I got side tracked and had put it in low ,it didn't bog down and then it was to late.
/ Bucket cylinder bent rod #19
Chromed rod stock is available if you have the machines to work with it. Typically, it's just a mater of cutting to length and threading both ends. Some welding may be needed for some ends. Many hydraulic shops have common sizes in stock. I bent a lift cylinder rod while it was up and carrying a load. Scared me more than anything. I was able to make a new rod the next day.
I had more trouble getting the load off the bucket than doing the repair. I was raising a car lift column onto studs when it bent. They were small cylinders though. I'm in the process of installing larger cylinders now.
/ Bucket cylinder bent rod #20
Back dragging with the bucket at beyond 45 degrees in float or not is still likely to bend the cylinder. Attempting to backdrag brush is pretty much guaranteed to bend something.
