Sickle mower for CS2410?
/ Sickle mower for CS2410? #1
Bannie
1955 Farmall 400, 2009 Bobcat CT122, Kioti CS2410
Hello.
I was wondering if there are any sickle mowers that would fit a Kioti CS 2410 with 3 point hitch?
Have some grasslands that we've been cutting with a brush mower but a sickle mower would probably cut a wider path more efficiently.
What are you guys running?
/ Sickle mower for CS2410? #2
I bought a 7' Enorossi (Farm-Maxx) from Carver Equipment a couple years ago.
I run it on a DK 35.
I got the hydraulic kit model, so I can adjust the mower cutter bar angle from 75 degree down to 90 degree up (or anywhere in between) while mowing on the go.
/ Sickle mower for CS2410? #3
Hello.
I have a 5 ft Enorossi and it is a heavy mower and they don't like mowing going slow. Grass just lays on top of the cutter bar. If you have fields that are yard smooth and flat where you can run 5+ mph then you might be ok.
If I was you I'd keep the brush cutter or find a finish mower if you want a better cut.
2021 KOBOTA SVL 97-2 SKID STEER (A65053)
2021 KOBOTA SVL...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2022 EZ-GO ELITE...
2006 John Deere 6420 (A64126)
2006 John Deere...
