Fuel stabalizer
/ Fuel stabalizer #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Im tired of having problems with small engine carbs and I plan to do something about it.
In my area finding ethanol free gas isnt easy and from what I have read dosent necessarily solve the problem.
I know that running the fuel tank empty at the end of the season isnt the answer either because Ive seen first hand the powdery white residue left behind after things dry out.
What do you guys do to not have any problems?
Im looking into a fuel additive called Sta-Bil. I know little about any of these additives.
/ Fuel stabalizer #3
You have had small engine carb issues because your useing un stabilized E10 fuel. Stabil will help but E0 fuel that's stabilized will really help.
How hard is it to find E0 fuel? Did you use pure-gas.com to final a local station?
/ Fuel stabalizer #4
it's here actually but it's not local (15 miles from here) and it's super expensive to boot. Marine Stabil works just as well.
/ Fuel stabalizer #5
My boat mechanic said the "blue" stabilizer from StarBright is best for my 2-cycle engine. On everything else, (gator,Tractor, mower...) I use Sea Foam. I am not a chemist, so I cannot say what ingredients are the best in what percentage, but many people I know use this for Gas/Diesel fuel. Many products out there, hard to know. In the past, had used Diesel Kleen for the tractor.
All that said, my opinion is like grease - best to always grease it.
/ Fuel stabalizer #6
I've used Stabil or it's Canadian Tire knock off since.....forever, never had a problem with fuel going bad. I add a 30-50ml to a 10L can everytime I get fuel as I never know how long the fuel will be sitting. If I know something will be laid up for awhile I'll overdose it. Had a tank of fuel in my woodspliiter for well over a year, probably closer to two years, second pull and away she went and ran the tank dry without a hitch.
Mind you saying that, our fuel here (Nova Scotia) doesn't have methanol it's actually gas and gas only. I check it every couple of months...........Mike
/ Fuel stabalizer #8
Bottom line here is.. If the gummit didn't fool with motor fuel in the first place, none of the elixir's would be required.
Sad but definitely true...........Mike
/ Fuel stabalizer #9
I use Stabil in all the gas that goes into small engines and the car I store over the winter and have had no problems. I can only get E-10 here and haven't had issues. I'm not sure how much worse E-10 is than pure gasoline, but Stabil extended the life of pure gas also. It's not purely an E-10 problem.
/ Fuel stabalizer #10
Been using StaBil in my gas powered equipment for about 30 yrs and have had zero carb problems. Even my little push mower that sits a year or two between uses fires right up with one or two pulls of the starter rope with StaBil in it. I also use their marine formula in my boat and their diesel formula in my tractor and have zero issues. It’s good stuff, just be mindful of where you store your equipment and fuel; if you leave either out in the elements and water collects in it you’ll still have problems. But barring water and dirt intrusion StaBil will keep your carbs clean and your fuel fresh.
/ Fuel stabalizer #11
I use SeaFoam. No issues to date. For E10 or Conventional.
/ Fuel stabalizer #13
Like others have said "Gold Eagle Sta-bil 360 Marine Formula Ethanol Treatment" seems to work good and I have been using it since it became available.
Just out of habit, I still run the carburetor empty on small engines (like the old 6 hp Tecumseh on a Troy Bilt Horse) that have a fuel petcock.
/ Fuel stabalizer #14
although seasonal fuel drain off to a dry tank has long been a tradition, i no longer use the method. while back had to replace a fuel shut off solenoid on my Kawi after a dry run...attribute that to gumming the needle when dry
as with the consensus, i only use ethanol free premium w/stabil. that works best for me
know the dry out method works for some & will continue to use it on my genset, but not my other small engines.
/ Fuel stabalizer #15
Want reasonable results, anything that will sit for 4+ months and takes gas use 97 or higher octane only and keep the fuel tank full. This will stop the oxidative and condensation from forming in your tank. If it will sit longer than 6 months, use a stabilizer.
If your equipment cant handle 97+, use farm fuel/marked if you can get it, add the stabilizer for anything you will not use in less than a month. If the equipment is going to sit longer than a month you have two options: drain both the carb and fuel tank (fog metal fuel tanks), or run the carb dry and fully fill the fuel tank with stabilized fuel.
The reason for farm/marked, aside it being allowed for small engines and offroad/marine without a farm license (though some stations are sticky about that), the E level is lower than it is in the comparable "grade" of pump gas.
2 stroke carbs should always be run dry and drained if you can help it, the oil helps but some 2 stroke oils still get gummy when they settle out of the fuel.
I have one stupid techumseh that the carb comes off when I stop using it since nothing seems to help it and it is finicky even when it works.
/ Fuel stabalizer #16
That includes 2cycle pre-mix, even though most claim to have stabilizers, they do not work like StaBil. Learned the hard way. Now I use it in everything that is not going to be ran out in a few weeks.
/ Fuel stabalizer #17
Amsoil Quickshot is what I have used since it was developed years ago. Never had a fuel issue so far.
And I agree, more and more professionals say to NOT drain the fuel, it causes more problems. Properly treated 87 or preferably 89 octane fuel with no more than 10% ethanol is just fine.
I also use Amsoil 2 stoke oil for premix since it came to market and none of my 2 strokes (chainsaws or string trimmers) have had any fuel issues and the chainsaws often sit for many months at a time.
I have tried E0 91 octane but like others said, it's not close (15-20 miles away) and cost almost double that of 87/89 E-10.
/ Fuel stabalizer #18
Saeafoam works and its a proven product, plus you can get it at Northern Tool for $7. Over the weekend we picked up 10 cans and use it in all our occasional use gas engines. No fluff, it works.
/ Fuel stabalizer
I have some tools I might pick up to use for a few hours one day and then not touch it again for several years, Im guessing running it dry is really the only option other than hoping for the best.
/ Fuel stabalizer #20
One reason why I have a heated ultrasonic cleaner with Berryman's B12 Chem tool in it. 175 degree Berrymans in the vibrator will clean any gunked up carby.
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
