V518 vs V519
/ V518 vs V519 #1
60047
Still searching
It appears that the V518 Versahandler has a 100hp engine. To anyone who has operated both, does the older V518 seem more capable than the V519, which only has 74hp?
Do both models have the power Bob-tach system for attachments?
@Xfaxman Have you ever tried unloading a 20’ shipping container from a trailer with any of your telehandlers?
/ V518 vs V519 #2
No, just the V519.
This is the hydraulic powered V518 system:
I bought an adapter to SSQA for my grapple:
No, this live tree was probably about the heaviest thing lifted:
And the heaviest thing moved, it was settled down in the dirt and the trailer movers couldn't move it with their truck:
/ V518 vs V519
25hp is substantial. I’m wondering how noticeable the loss of power is on the V519.
Does your SSQA adapter allow you to detach/attach non-hydraulic attachments from inside the cab?
/ V518 vs V519 #4
No, this one had two manual levers.
/ V518 vs V519
What attachments is the standard hydraulic coupling compatible with?
/ V518 vs V519 #6
If you are asking about the V518, ones made for the Bobcat telehandler style attach pictured above. The attachments for it are not on the Website since they quit selling the V518.
What do you need?
/ V518 vs V519
oh, so the V518 coupler only supports a few V518-specific attachments.
I’ll be looking for a grapple, toothed bucket, stump bucket, forks, and post driver.
Can you reverse your auxiliary hydraulics to run a PTO-tiller in reverse?
/ V518 vs V519 #8
V518 plus V624, V632 and V723. Don't know if the V923 is the same size.
I think you would be happier with a V519.
Yes, but a PTO tiller would have to have a hydraulic motor added.
I can run the brush hog either direction on the V417. The blades are sharp on both sides. I do one way for grass and the other way for brush:
/ V518 vs V519
Yeah, I've started to settle on searching for a v519.
Out of curiosity, how different was your old v417 from the v518?
And how much more work (in percentage terms) can you get done with your v518 when compared to your Toolcat?
/ V518 vs V519 #10
The V417 is narrower, doesn't have as good of a tire tread pattern, but has a door and air conditioning.
The lower 75 horsepower rating was not noticeable since the machine did everything that I tried to do with it.
The big advantage was the SSQA.
The V518, used bought 9-23-2009:
The V417, new bought 9-29-2010:
The machines are very different. My wife bought the Toolcat in December 2012 so she could help with mowing without getting poison ivy.
It does better mowing because of the suspension:
They both can lift the 1 cubic yard bucket full of clay:
But not as high:
And I don't try removing trees with the Toolcat. :)
/ V518 vs V519
I just sold my Kubota L4330 yesterday, so I am actively looking for the replacement machine. It's a tough choice between the v417/v519 and 5600/5610. Used 5610 machines are really hard to find. The v519 is looking out of my budget, so if I want the SSQA, then I guess I will focus on the v417.
The one attractive thing about the Toolcats is that it allows one of the kids to ride around with me while I get stuff done. It's only a few more years before they'll have absolutely no interest in that, so it does have some value right now--even at the expense of getting more heavy-duty work done.
/ V518 vs V519 #12
Well I can recommend the 5610, have you seen this thread with both machines? Toolcat and V417
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
John Deere 4440 (A64119)
John Deere 4440...
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
