Can't find oil filter
   / Can't find oil filter #1
Blue Mule
Central Kentucky
New Holland Workmaster 40
2019 Workmaster 40. Looking for an engine oil filter yesterday....
Dealership says they've been waiting for months.
NAPA says they can't even look up a filter for it.
O'reilly Auto Parts also has no listings for it.
I ended up ordering one from Messick's hoping it's the correct filter. Should be here in a week or so, I hope.
This is ridiculous.
   / Can't find oil filter #2
What is your OEM filter # and make? did you try WiX. For my 1700 I use WiX equal and am pretty happy with.
   / Can't find oil filter #4
+1 for Messicks,they should be able to fix you up.I have a 2017 Workmaster 40 and buy my parts there.
   / Can't find oil filter #5
You may be able to cross by dimensions. You need the hole diameter and thread pitch as well as the seal diameter. If you can get those off your old filter you may find it's common.
   / Can't find oil filter #8
I checked t with Wix filter look up. They have hyd filter , air and fuel but do not list oil filter. Below link might come handy for future reference.
something else to look,
   / Can't find oil filter #9
I have been using Quaker State QS 3600 (long filter) for years on my NH. Matches a Fram PH3600 and I have used a few of those. If length is an issue the QS 3614 is the shorter version.
   / Can't find oil filter #10
A wix filter cross to the 84475542 NH is a wix 51348 or 51348xp......a very common filter.
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
New/Unused Stainless Steel 87in 32 Drawer & 2 Cabinet Work Bench (A54865)
New/Unused...
Miscellaneous Vehicle Exhaust Pipes (A53425)
Miscellaneous...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55302)
1988 Kenworth...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
