FIXED IT- NO MORE LEAKS---4x4 front left leaking oil onto rim and tire
   / FIXED IT- NO MORE LEAKS---4x4 front left leaking oil onto rim and tire #1
macdoesit
Mitsubishi MT 2801fd Loader
Mitsubishi MT2801fd 4x4 with loader
Fluid running down on inside front left wheel.
Need help on replacing oil seal, maybe bearings, I can see on inside rim where about 5 inches is being rubbed by something. Can't see that it is rubbing anything, maybe a rock or stick got behind the rim.
If anyone has done this could you help me out, maybe there is a video somewhere. If not I will attempt myself and video start to finish so all parts will be documented where they go. Can someone tell me where to start on disassembly.
Do I need any specialty tools.
Thank you
   / FIXED IT- NO MORE LEAKS---4x4 front left leaking oil onto rim and tire #3
If you cant take something appart and put it back together I would take it to a place that can do that for you.
I need to know what comes off first.
As many as it takes.
More to it than just take apart and back together. Have you ever done it.
   / FIXED IT- NO MORE LEAKS---4x4 front left leaking oil onto rim and tire #7
Fixed the leaks.
   / FIXED IT- NO MORE LEAKS---4x4 front left leaking oil onto rim and tire #9
This thread has been so helpful! Thanks to all !
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2017 Ford Expedition SUV (A50324)
2017 Ford...
19200 (A50324)
19200 (A50324)
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
