Changing front axle to gear oil question
   / Changing front axle to gear oil question
My 6530 IS a 2007 model and the manual specs HTD fluid. I tore up my front ball bearings in a stupid mistake and refilled with 85W-140 since I live in Tx. otherwise would have been the lighter gear oil....no problems since. I bought a 2016 2400 and the manual and even the fill plug had 85-90 Gear oil specified. I think that Branson for one realized that HTD fluid has it limitations.
May I ask what mistake you made that caused you to destroy your ball bearings?
   / Changing front axle to gear oil question #22
Thinking might switch to Lucas synthetic 75/140 gear oil in the front axle next time instead of the conventional 75/90 wt gear oil. Kubota M59, single compartment front axle and hubs, 11qts, 95% in four wheel drive.
Synthetic 75/140 shouldn’t be thicker at cold temp than synthetic 75/90??? But better viscosity at higher temp??? Probably much I don’t understand.
   / Changing front axle to gear oil question #23
First number is cold temp viscosity/ second number is viscosity at its rated operating temperature.
   / Changing front axle to gear oil question #24
Nope, hydraulic oil is spec for Kubota front ends.
So is hypoid oil as the alternative (always has been). Far as tearing up the ball bearings in the outboards, pretty easy to do in as much as they should be roller and not ball bearings. Exceeding rated capacity on the usually included FEL can and will eventually destroy them. One reason why I switched to hypoid oil versus the SUDT. Those ball bearings in the outboards need all the help they can get.
   / Changing front axle to gear oil question #25
Lots of people use 4wd in high range and on hardpack/concrete counter to their manual. The windup has more impact than the FEL load does.
   / Changing front axle to gear oil question #26
Sorry for my ignorance but does this mean gear oil is more likely to be contaminated with water than UDT over time?
yeah because good hydraulic fluids have the ability to displace moisture / water where gear oil don't. But long as it's changed as stated it will be fine unless leaks allowing water in.
   / Changing front axle to gear oil question #27
On my 2 M's, the front axle oil gets changed every 2 years and inspected (for water) every time I change the engine oil. I use them hard.
   / Changing front axle to gear oil question #28
I haven't had either of mine in FWA in a long time. No need to use it for what I do. More of a selling point for me than anything else. I will be using it shortly, have some stumps to yank.
   / Changing front axle to gear oil question #29
That is a good sequence!
I am to lazy to keep track and do everything at 100 hours.
   / Changing front axle to gear oil question #30
I had a small leak with the UDT, so I changed to 80/90 Gear Oil about 100-150 hrs ago, and the leak went away. All I did was drain and fill, and have had no problems since.
I drained my JD 4105 and refilled it with 140W that I found a 2.5 gallon jug of at TSC,,
My axle was leaking, and after the change, it still leaked a little, I think the residual UDT oil was enough to "thin" the new gear oil,,
I drained it again, and refilled it again,, and that was the LAST of my front end leaks!! (y)
The tractor is a 2012 model year,, I did the change in either 2016 or 2017,,
So, the gear oil might be in use longer than the UDT oil was,,
1981 JOHN DEERE 570A MOTORGRADER (A52707)
1981 JOHN DEERE...
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
John Deere 3pt 2 Row Planter (A53317)
John Deere 3pt 2...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
