3901 HST RPM for engaging PTO vs RPM for operation
   / 3901 HST RPM for engaging PTO vs RPM for operation #1
CindyCRNA
Member
Near Kansas City Kansas
L3901 HST
Getting ready to mow and for the life of me, I cannot remember what RPM to use to engage the PTO. Haven't mowed since last fall and a wet spring has backed everything up a bit here. I am new to this tractor. I believe it is 2300 RPM to engage then......3000 for operation? Running a brush hog.
   / 3901 HST RPM for engaging PTO vs RPM for operation #3
I always engage my PTO at a dead idle, then bring the throttle up to PTO speed. YMMV
That's what I would do. I'm a long time tractor guy and not sure there is a hard and fast rule on this, but there is "good practice". I'd try it at low idle at first - and if it bogs engine down then next time try engaging at a 100 RPM higher. Continue until it "feels" and sounds good.
Engaging at 2300 seems way to high to me. Expecting gears to mesh when something is turning that fast is just asking for a broken PTO gear. That 2300 sounds more like an RPM you would advance to for heavy cutting than a speed at which you would engage the PTO.
BTW, I don't necessarily run it at the "rated" RPM either. I consider that the rated PTO speed is simply the engine RPM at which the PTO is turning 540 RPM and for some jobs that is right but not for all. I will rarely exceed the rated RPM, and then only for a tiny bit and not for long. But I will commonly back off on the engine RPM until the mower is running smoothly for the cutting conditions and the tractor speed over the ground.
Some Kubotas had a foot clutch along with the HST. Ours does, and it would be nice if every tractor had a manual PTO clutch. It it has a manual PTO clutch or a foot clutch then use that when engaging the PTO. With a clutch you can engage the PTO at any RPM without stressing the gears. But even then, it is better to engage at a low RPM and and then once engaged raise the RPM up to operating RPM just slightly before or as you start moving forward.
enjoy,
rScotty
   / 3901 HST RPM for engaging PTO vs RPM for operation #4
I have two vehicles that have PTO operation.
My JD X570 riding mower. It has a button for electric PTO - on/off. I engage at just a tad above dead idle.
My Kubota M6040 - it has a lever that enacts the PTO operation. Again, I initiate operation at around 850 rpms. Slowly but positively push the lever forward. When all is up and spinning - bring the tractor up to PTO speed. 2160 engine rpm = 540 PTO rpm.
   / 3901 HST RPM for engaging PTO vs RPM for operation #5
Engage the PTO as low of RPMs as you can without stalling the engine.
The economy Ls use a foot clutch to engage the PTO (at least my old L3200 did). So you can engage it pretty gently. The faster it engages the easier it is on the clutch though.
On my L4060 & other Grands it's just a switch (electric over hydraulic). There is no way to ease on the PTO clutch. I've stalled it a few times with my heavy flail mower. So I kick it up from an idle to 1,000rpm or so before engaging. It will usually engage at an idle, but I'd rather wear the clutch out a bit more than stall the engine. My tiller has almost no load when it's lifted out of the ground unlike the flail,, so I pay less attention to engine RPM when engaging the PTO. High or low RPM there is no engine bogging or prolonged clutch slipping.
Engaging any kind of clutch at higher than needed RPMs will just wear the clutch out faster for little to no benefit.
   / 3901 HST RPM for engaging PTO vs RPM for operation #6
My Kubota mechanic suggested depressing the clutch and engaging PTO at idle, then bring it up to speed. He strongly recommended depressing the clutch when disengaging the PTO as well as just popping it out of PTO can potentially cause undue wear to PTO gear faces.
   / 3901 HST RPM for engaging PTO vs RPM for operation #7
Not so much gears, it's hell on the PTO clutch.
It has a clutch . Run the RPM up to speed (I will get the book out, ) depress the clutch, engage the PTO and slowly back off the clutch which allows it to slowly spin up the PTO. I don't know why but I love that sound!
   / 3901 HST RPM for engaging PTO vs RPM for operation #9
OMG-Please don't!
Please let out the clutch smoothly at idle after you engage the PTO.
Then,and only then,increase the RPMs.
Good Luck!
   / 3901 HST RPM for engaging PTO vs RPM for operation #10
It’ll probably stall the tractor at idle but engage it at as slow of an RPM as possible. 1200-1500 will probably work.
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
