Removing / unscrewing a broken off pvc male adaptor
   / Removing / unscrewing a broken off pvc male adaptor #11
X2 on the heat to soften it up. It will back right out.
   / Removing / unscrewing a broken off pvc male adaptor #12
Heat would work if it did not have a rubber seat or something else and i believe they do. I do know it's not metal to metal seat.
   / Removing / unscrewing a broken off pvc male adaptor #13
I have one of these but not with a removable bit. It's the tool that could not be inserted far enough otherwise it bottomed out first.
Many good ideas-- I will try them, and I will look for this same tool with a larger auger. Thanks!
What's the inner diameter of the broken part right now?
I'd be interested to see a pic of what you're dealing with and how you solve the problem eventually.
   / Removing / unscrewing a broken off pvc male adaptor #14
If it's 3/4" PVC...the inside diameter should be 3/4"...
   / Removing / unscrewing a broken off pvc male adaptor #15
Presumably, though there could be a 1"-3/4" reducer at the bottom of 3/4" pvc pipe; I haven't seen an extractor for 1" is why I asked.
My pvc extractors are for 1/2" and 3/4"; I guess plowhog's extractor is the 1/2"
   / Removing / unscrewing a broken off pvc male adaptor #16
I have this problem regularly for our horse waterers, although it's 1/2 inch pvc. I ream it with a stepped drill bit until the PVC is super thin, usually comes right out by then. I've also sawn notches in the pvc at 180 degrees from the other then stick a knife or other tool in and turn by hand - not always successful with that. I try to use dull blades so the threads of the metal pipe don't get buggered.
I'll get a photo and post it in the next day.
OK getting this plastic male adaptor out is turning out to be a b-i-t-c-h.
I found a tool at Home Depot *supposedly* just for this job. But like the other tool I tried, I had a hard time inserting it far enough to get a good bite. It bumps up against the seat of the freezeless hydrant. But I got enough of a bite to seemingly back out the broken male adaptor. It has a cam that expands as you back it out. No go. The special tool won't stay in line with the pipe, and it wants to wander to the size as I try to unscrew it. Some of the damage at the edge of the pipe was actually caused by that tool. I got enough bite on it to leave serrations on the inside of the plastic fitting-- but it still would not budge.
I tried heating the pipe. I didn't use a torch because the freezeless hydrant seat looks to be rubber. So I used a propane Mr. Heater and set the fitting above it. And turned it once or twice to heat it all around. Still, nothing would back out the plastic male adaptor. I tried turning by hand, using the tool, and the tried and true chisel and a hammer. I'm pretty sure the fitting was glued in. I can also see some teflon tape sticking out on the far side of the threads.
I was able to pry the plastic fitting from the side-- making sure to pry away from the threads. That successfully broke a small piece out. That's as far as I got.
I don't want to create (more) damage so I will have to try again tomorrow .... it is seated in there TIGHT!
   / Removing / unscrewing a broken off pvc male adaptor #20
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Sterling AT (A55302)
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
