Winch
/ Winch #1
marhar
Gold Member
Denton NC
Farm Trac 60
Does anyone have any experience adding a winch to a 2 wheel drive tractor? Sometimes I do dumb stuff. I have never been stuck crossing a creek, I lock the differential. I do not want to be calling a tow truck or back hoe to pull me out if I do get stuck.
/ Winch #2
Electric winches are designed for "recovery" not for every day projects like log skidding and general work, that said, a electric winch can save you when you get stuck, what is important is determining what size winch you may need to recover you tractor from its "stuck" position, maybe a 3500# or 5000# or 9000# winch may be needed.... Main aspect of using electric winch for recovery is how robust is you tractors electrical system, questions that need answers is what is amperage output of alternator/generator and how big (CCA) is you battery.... Also consider distance you may need to pull to get unstuck, the longer the pull the more strain on tractors electrical system... A really good winch and a really stuck tractor can put up to 200-300 amp draw in electrical system during winching operation... Year or so ago I was crossing a seasonal creek and absolutely stuck my 4WD SCUT and had to get my Jeep with 10,000# winch on it to pull tractor free... Lots of strain on winch, pull actual slid 4500 pound Jeep across the dirt until I blocked all 4 wheels and progress was slow for first couple of feet (stain on Jeeps electrical system (100 amp alternator and 900 CCA AGM battery)), I mention this because yes winch can be your savior but there is a lot of variable involved in any situation...
/ Winch #3
I built an hydraulic winch myself, exactly for the same reasons. Sometimes I have to do some brush mowing for someone else on ground I don't know, with hidden holes, creeks, etc that the tractor can get stuck. Usually there is no way to get on those places, other than with a tractor. I would just attach the winch to a tree and get out of there.
So I decided to build a winch and mount it on the front of the tractors. It's literally one of the best things I ever made. It has came so handy for some many tasks. I've pulled trees when cutting so it doesn't fall on the wrong side, I've stretched fence wire, I've pulled cars that weren't running. The list goes on and on. Interestingly enough, I've never got stuck and used it that way.
I have a built thread here: Hydraulic winch
/ Winch #4
I have a 4 wheel drive tractor (Kubota L235) around 2000# - when you get a 4 wheel drive stuck, it's really stuck and I've done that once and no longer get into those situations. However, recently, I did put an electric winch on the front of my tractor for infrequent winching. It's a 2500# ATV winch that I bolted to the part of the frame that carries the suitcase weights. You do have to watch the current draw, but so far I've only pulled 2 logs out of the forest. It's there Just-in-case since I'm a lot farther from help than I used to be.
/ Winch
Nice, Thank you for sharing.
/ Winch #7
I too am planning a winch for the front of my Yanmar for similar reasons, to get me out of trouble. I have a nice 9K winch sitting in the garage and I came across this winch mount that will provide a nice starting point. In my Jeep I have it setup with a dual post high CCA battery and has performed well over the years.
/ Winch #8
I've got my M6040 "stuck" exactly two times. Both times - due to slick clay like ground. The tires loaded up and we went nowhere.
Both time I pulled myself out with a manual cable come along and use of the bucket on the FEL.
All my adult life I've owned one type or other vehicle with a winch. An electric winch can be a God send OR it can become a real PITA. They can put a tremendous strain on the vehicle electrical system and can/will fry components in less than a heart beat.
Just be certain that you know what you are doing and don't complicate situations with cheap components.
/ Winch #9
Really nice looking work there!
Would like to utilize the PTO transmission on my Ram for a bumper mount hydraulic winch, but it would cost mega $$$
Tractor winches much better since the cleated R1’s less prone to sliding.
I have a winch on my Rubicon, but it lacks the azz to pull anything really heavy.
/ Winch #10
There was a fellow with a 1945 Dodge Power Wagon in our 4WD club. It had a front bumper mount PTO driven winch. It had POWER beyond compare. It was also slower than molasses in January. The setup was OEM.
For that matter the Power Wagon itself was slow. IIRC - it topped out at around 45 mph.
/ Winch #11
Thank you!
That would indeed be a killer setup. The PTO pump would be the way to go as it would allow you to run a bigger pump and get some nice speed out of the winch versus running one using a belt drive of the crankshaft.
The 90's Mitsubishi Pajero/Montero had an option for a PTO driven winch, a fully mechanical setup. Really neat, crazy powerful but a very very rare option. From looking at some videos, it had a very decent speed for a recovery winch.
/ Winch #12
HF has a nice line of HD winches with excellent reviews on off road magazines. Their line of Badland winches work for me, have one on my side by side but my 350 Ford has a Mile Marker hydraulic winch that runs off the power steering pump. Had it for years, used it a couple times, always works.
/ Winch #13
You could get a pto winch for the old IH Scouts also and I had a 73 Toyota FJ Land Cruiser with it.
Those actually ran off of the transfer case, with the transfer case in neutral and the pto engaged you
could select any gear to vary the winch speed
/ Winch #15
I've got a 1951 Dodge M37 truck, which was basically a military version of a Power Wagon (Power Wagon purists, please don't get upset at my use of the term. I know it's not a Power Wagon.) it does share a lot of components with the Power Wagons of that era.
The PTO winch some of them came with from the factory was a Braden LU-4, rated at 7500#. (Though there are plenty who claim it will pull a lot more than that - and it probably will.)
/ Winch #16
Years back our family company owned about a 1/2 dozen Korean War surplus Dodge Weapons Carriers that used their industrial flathead 6, had 6 wheel drive with a huge military pto winch and seats on each front fender for the Mine detector operators. My Dad and I cleared a few acres mostly of mostly Pin oak for a new house. Not sure of the capacity but she carried a 5/8" cable and we would pull up to a tree and just kiss the bumper, then wrap a stump about 30 feet away and yank out 12" stumps like pulling weeds out of a garden.
/ Winch #17
The winch isn't too bad, $2100 for 18,000 pound winch.
Of course then the 16 gpm pump and reservoir for it will add up.
PIERCE™ Planetary Hydraulic Winches (18,000 LBS.): 19.4:1 Ratio, 23 FPM, 15.9 GPM
/ Winch #18
My CUT rear weight incorporates a hitch receiver tube.
I bolted a fair sized winch on a plate that I welded onto a 2" tube.
Also installed an Anderson plug for power.
I haven't needed it often but sure does the job whenever I wish to retrieve something and or pull myself out of a jam.
I've also retrieved a fair number of trees for firewood.
Only downside is current draw vs battery and alternator capacity so that needs monitoring.
OK for occasional usage but for sure not serious logging operations.
/ Winch #19
Set up so it can be used on truck,trailer, Tractor front or rear
2018 Ford Expedition MAX Multipurpose Vehicle (MPV), VIN # 1FMJK1KTXJEA37391 (A61165)
2018 Ford...
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
Case skid steer wheels and tires (A63118)
Case skid steer...
John Deere 5525 (A60462)
John Deere 5525...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2022 Kubota Z422-54 Zero Turn Mower (A63118)
2022 Kubota...
