Did you guys know this about outlets? I didn't!
   / Did you guys know this about outlets? I didn't! #11
Grounds are placed up in commercial applications where metal coverplates are used. This way if a plate were to come loose it won’t drop down and short across the hot and neutral when plug is pulled out. I never install them with ground up in residential.
   / Did you guys know this about outlets? I didn't! #12
Ground down to make it look like a face. :)
Bruce
   / Did you guys know this about outlets? I didn't! #13
What about those outlets you somtimes see that are mounted sideways. Ground pole to the left or to the right?
   / Did you guys know this about outlets? I didn't! #14
Darn. Completely wired our house here when I built it. NEVER knew of tool #2. Bought an expensive pair of wire stripping pliers.
Hey guys interesting info about installing the outlet with ground up. Some plugs fit better ground down vs up (for instance with a flat face space-saving prongs), so I just install the outlet to fit the purpose when there is one. Otherwise, I never gave it much thought.
   / Did you guys know this about outlets? I didn't! #16
I can tell you for a fact what happens when the metal cover-plate falls down and shorts across the hot and neutral prongs.
I was installing a plug in surge suppressor and you use the center screw on a tab of the suppressor to hold the suppressor in so it cannot be removed without a screwdriver. When the metal cover-plate accidentally fell down across the two prongs, oh, boy that was fun, then I got to hunt up the breaker box too!.
   / Did you guys know this about outlets? I didn't! #17
On sideways plugs if you face the ground pointing left, the neutral side (the larger of the flat blades) will point up. Safer than the line side up.
   / Did you guys know this about outlets? I didn't! #18
Wow, I never knew about the strippers. Enjoyed watching the video without commercials too!
   / Did you guys know this about outlets? I didn't! #19
Solid wire easier to skin than stranded wire. ;)
   / Did you guys know this about outlets? I didn't! #20
I too have had a plug short out from dropping something metal so I started doing ground prong up. In my case it was a combination square I was holding while unplugging a drill and it slipped out of my hands and shorted right across the plug. After a while I stopped and went back to normal as the ground prong "up" puts enormous stress on the ground pin on an extension cord as it tries to bend down from the weight of the cord (heavy duty construction cords, not lightweight residential ones). I started to see the ground pins get pulled out of the plug on the cord. After the second extension cord did that on me I changed my ways.
2012 Dodge Journey SUV (A55758)
2012 Dodge Journey...
2019 LOAD TRAIL REM GOOSENECK (A55745)
2019 LOAD TRAIL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1998 Volvo VN T/A Dump Truck (A55788)
1998 Volvo VN T/A...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
