Pat's Easy Change Adjustment bolt size on Pat's Easy Change and a short introduction for a new member
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #1
barrywlarson
Kubota L3560
Hi:
I am in the process of purchasing a set of Pat's Easy Change brackets Cat 1 for my Kubota tractor (L3560). I have read a number of reports about the stock bolts being too soft and plan to replace my with hard steel Allen screws (with Loctite) or grade 8 bolts at least when I install the brackets. I am going with Pat's system as opposed to a solid quick hitch as I am acquiring a variety of attachments of different makes and vintages. I'm not fussy about looks as long as they do the job intended. Can somebody tell me the size of bolts used so I can buy appropriate sized replacements. Right now the tractor some distance from my current residence and my bolt supplier is close by so I might as well take the replacements with me next time I travel to my property.
By the way I'm new to the group, but have already learned a lot from the membership here. As a way of introduction I grew up on a small farm in north-central Saskatchewan, Canada - Case tractors and combines and a menagerie of implements - too poor to afford John Deere:<). I worked in the oil and gas industry for 40 years and my wife and I bought an acreage near where she grew up in south-western Ontario (near London). The property is big enough for a tractor and implements and I'm not young enough for a shovel anymore:<)! I'll be back asking questions about three point hitches as everything on the farm was towed, unlike southern Ontario where three point hitches are very common and most of the used small implements I run across to buy used are three point hitch.
Any and all advice is appreciated. Thanks in advance.
Barry W. Larson
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #3
Hi:
Barry W. Larson
I have the Pat's Easy change system.
The bolts they ship with are grade 2, and are definitely junk.
I would suggest that you might want to reconsider your grade 8 choice.
I replaced my bolts with grade 5.
If you break a grade 8 bolt off, it will be quite tough to drill it out.
Thanks. If grade 5 are sufficient that's what I'll go with. Grade 8 or set screw's are hard to deal with but there are ways:<).
Cheers,
Barry
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #5
After using the bolts that came with the hitch to determine what lengths are needed,,
I went to TSC and purchased their Grade 8 bolts to make a nice, clean, installation.
It has been perfect for over two summers of mowing, etc,,,
Thanks. What size of grade 8 bolts did you buy?
Barry
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #7
Barry
The size will vary depending on the tractor to which it is installed,, I doubt my sizes would be right for your tractor.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #8
Barry
Just take one of your OEM bolts along, as a comparative size sample, when you go to get grade 5 or grade 8 replacements.
If you are very rural, and do not have a local bolt source, you can use the cheap OEM bolts until you have an opportunity to get replacements.
Actual replacement of the OEM bolts will only take a very few minutes.
BTW: Please consider adding your general Ontario location to your profile.
Some type of location information often makes it possible for those responding to provide more meaningful advice.
Please do not use Lower Uncton as your location!:laughing: (some here will understand)
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #10
I like your wheelbarrow, Cadplans
A neighbor had that steel wheel, and one foot of one handle bar laying in his scrap pile,,
I asked if I could have it,, he thought I was crazy,,
I brought it home, and fabricated the wood parts from "guess" dimensions,, all pressure treated,,
The rear steel "legs" came from a surplus store, they only had the legs off of wheelbarrows,,
I built it as a decoration for my shed,, everyone comments about it,,, :thumbsup::D
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #11
What about the U bolt? I don't think I ever saw a strength rating on one of those.....I'd certainly want to upgrade it too. On 5 vs 8, 8 is brittle and when it hits it's shear strength, it snaps. 2 just smears, and 5 is a happy medium. Using a grade 8 in a PTO shaft and getting a good whack, if of the right intensity will snap it. Same whack on a 2 and if it shears, it smeears, but a lot of times it will partially shear and hold for another whack or two before it breaks.
In talking about PTO bolts, I find that using a locking nut and not tightening the nut all the way down, allowing for some slack, especially in older equipment makes a bid difference in shearing vs holding regardless of the bolt strength. On Pats application, I don't see that much of a shear moment to hurt an 8....but who knows till you try it, which I think I will do while thinking about it.....probably go with a 5 as I have bins full of them.
Thanks. Sounds like the audience says good grade 5 bolts are the way to go.
Cheers,
Barry
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #13
Even though it might seem to be so, I do not believe that the U bolt has frequently failed in the Pat's Easy Change system.
If the U bolt should fail, it would simply require the purchase of a new U bolt ( I think Pat's will send out a free new U bolt, or bolts if necessary).
If one of the 4 side bolts fails, it will require removing the mount, and then extracting the broken bolt from the casting.
Likely not terribly difficult, (unless it is a grade 8 replacement) but a real nuisance!
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #14
Just for grins, I ran numerous attempts through the google search engine and mild steel seems to be the only material from which most Ubolts are built. Mild steel comes in at Grade 2. On needed stronger or not, for an implement putting down pressure on the 3 pt, it's out of the circuit. It's the up lift I was thinking about since I am going to hang a 900#, side mounted drum mower off mine this spring and there is a lot of lifting "moment" on the left side when it is in the mow position and you lift it off the ground. Only other material was SS and it stopped at 3.5" length and Cat II Pats needs a 3/8x2.5x6.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #15
F.Y.I.
I just received my Pat's Quick Change Cat 1 today (June 18, 2021) and can confirm that the bolts that came with it are now Grade 5 (three bars on the bolt head).
Spread the word.
Denis
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #16
F.Y.I.
Spread the word.
Denis
A long overdue fix!
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #17
A long overdue fix!
I lost/broke a u bolt (can’t remember now) on a Pats Cat 1. Field repaired with small bar stock and threaded rods. Doing a web search for Pats I was unable to find their actual address/contact info (only resellers)
Can anyone provide a direct contact #. ?
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #18
The "YAW" adjustment bolts (four per side) on my Cat 1 Pat's EZ change are 3/8-16 X 1 3/4" of full thread. Grade 5 (two inch Over All Length with the hex head.
I suggest taking these bolts or any replacements to the bench grinder and tapering the first three threads just a bit. The ends mushroom out when tightened against the lift arms.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #19
As you consider using a better fastener, realize that engineers 'May' have specified a softer one so it becomes the shear point and thus cheaper and easier to replace than the next weakest link.
Not saying that what you are doing is wrong but rather something to think about what will break if the bolt does not. Best of luck.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #20
Well, here you go.
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 108,368 (A59231)
Year: 2015 Make...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
