ZD1011 Fuel Consumption and Compare to Z724KW
   / ZD1011 Fuel Consumption and Compare to Z724KW
Last question, how many of you with the ZD are strictly residential? Would it be considered an overkill?
   / ZD1011 Fuel Consumption and Compare to Z724KW #22
I bought my first ZD to mow just my 6 acres, and I never regretted it. The ZD326 now has 1800 hours with no major problems. Overkill? Probably, but they sure are reliable and long lasting.
Currently I'm mowing 30 acres across 16 rural properties, and the diesels are a perfect fit.
   / ZD1011 Fuel Consumption and Compare to Z724KW #23
I only mow my property but it is not overkill to me. It is the right tool for the job that I need. Honestly, I quit caring a long time ago about what others think about what I buy. Life is too short.
I always like to buy something with the intention of owning for a long time. With the hours I see these things going, I should have it many many years.
   / ZD1011 Fuel Consumption and Compare to Z724KW #25
I have a ZD221 54" that I bought new in 2014 to replace my Scag Tiger Cub 48". There was nothing wrong with the Scag I just wanted a newer mower and a diesel. I mow 1.5 acres weekly and fill the tank every 3 to 4 cuttings. I would not go back to a gas mower. I plan to keep this machine a long time. I don't think it's overkill.
Same here. I have a very good mower now 60" Badboy with a Kawa engine. But I figured in the long run and while I can get some money back on my current mower, that now is a good time to trade up. I think I'll be pleased. Should make delivery next week.
In regards to the chute, what are y'all's opinions on the Kubota chute blocker or the Advanced Chute system? Pros/Cons to each one?
   / ZD1011 Fuel Consumption and Compare to Z724KW #28
I have no experience with Kubota's chute blocker, but the Advanced Chute Systems works great on my ZD326 and 1211. I wouldn't be without one.
Pros :
-I can close or partially close the chute to prevent grass from plastering objects, or getting into flower beds. Even with close attention to my pattern there is always the occasion where I'm throwing the wrong way.
- 99% of the time I'm mowing with the chute wide open, dispersing clippings better than with a standard non adjustable chute.
- They're great at mulching leaves in the fall
Cons:
- Not cheap!
- With the chute closed, they leave a noticable windrow, so I have to go back over the row eventually.
Pros :
Cons:
- Not cheap!
I'm waiting on a quote for the Kubota brand but I can't find reviews or detailed photos online. The ACS has plenty of reviews.
   / ZD1011 Fuel Consumption and Compare to Z724KW #30
Pros :
Cons:
- Not cheap!
Can you post up a picture of it? I really want a chute blocker
2016 Dodge Charger Sedan (A50324)
2016 Dodge Charger...
2006 Ford F450 XL Bucket Truck (A47384)
2006 Ford F450 XL...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
