Hoping for an affordable solution….
   / Hoping for an affordable solution…. #1
kubota4me
USA
An orange one
I’ve got a Kubota compact tractor L4400-45 hp. Occasionally I mow My 10 acre prairie to help keep down invasives. I use a LandPride 6’ brush hog. I would like to have something to rake up what I mow and use it in my large country garden for mulch to keep weeds down. Probably only use 2-3 acres of hay. I tried putting a landscape rake on the back of my tractor to try to gather up the cut hay but that is too rough and tears up the prairie. I thought about a pine needle rake but not sure about that. I’ve been looking for a very small hay rake that could rake it into rows and then I would use my grapple to grab piles of it and take it to my garden. What do you think would be the best solution and still keep it affordable <$650? Thanks for your help!
   / Hoping for an affordable solution…. #2
Should be able to find an old reel rake for not much money.
A wheel rake is simpler, but probably more expensive, being a newer design.
Bruce
   / Hoping for an affordable solution…. #3
How is introducing weed seeds with your pasture clippings going to keep weeds down in your garden?
   / Hoping for an affordable solution…. #4
I had the same question as Dusty. I put a layer of hay and horse droppings onto the garden and can now harvest many kinds of weeds. Mulch may act as a good ground cover but if you're mowing to reduce weed content on your pasture you'll be moving the seeds to your garden.
   / Hoping for an affordable solution…. #5
Compost the cuttings before you put it on the garden. This will reduce the seed transfer. Also cut the weeds before they go to seed. It is amazing how many people do not time the mowing of the pastures correctly.
   / Hoping for an affordable solution…. #6
I used hay to protect seedlings in the garden once. The garden now produces a good crop of weeds every year. 😏
We garden using the Ruth Stout method and we have had hay/mulch 18” high. It is so much mulch that any weed seeds are blocked from the sun and unable to germinate.
We time any mowing and prescribed burns to coincide with the needs of the prairie. If we want more tall grass prairie i.e. Indian Grass and Big Bluestem, we burn or mow in the spring. If we want more forbs in our prairie, we have a fall burn or late season mowing. Our prairie is a prairie remnant that has never been tilled. Less than 1/10th of 1% of original prairie is all that still exists in Iowa. Ours is part of a landform in the Loess Hills that formed approximately 12,000-18,000 years ago when the last glacier receeded and winds swept the loess particles up and deposited them in what is called the Loess Hills.
18” of mulch in the garden using the Ruth Stout method of gardening. We never have weeds in the garden. Look it up on YouTube if the spirit moves you.
   / Hoping for an affordable solution…. #10
we found that using good alfalfa as mulch in the garden worked very well. i would not use field grass mowing's, no way.
Utility Cart (A59228)
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2017 John Deere 5090GN (A53317)
2017 John Deere...
