BATTERIES
   / BATTERIES #1
Crawl
North Florida
Massey-Ferguson 180
Any suggestions on the best batteries? 1968 M-F 180, 70hp Perkins diesel with generator/regulator.
   / BATTERIES #2
Hey Crawl ! Welcome to TBN I own a 1959 M-F 50 with a Continental gasoline engine I've been using nothing but Interstate Batteries, Farm/Agriculture & I'm on my 3rd set after 22 years & this is just a suggestion ! So I've been averaging 7 years of service out of each battery with out any charging or jumps.Hope You find what brand suits your needs.
   / BATTERIES
can do... I'll give Interstate Batteries a look. Thank you for your response.
   / BATTERIES #4
Hey Crawl ! Have You had a chance to look around at anything else in the battery world ? My newer M-F 1526 (2018) has a Delkor battery in it & it seems to be holding up very well , Also I use to operate power jacks & lifts at work ( Crown ) in temps -20 degrees yes -20 & they used Deka batteries in them & I see that your down in Fla. so I guess that is a different temp. extreme. But the Deka batteries held up very well in those temps & didn't require daily charging. Anyhow when I need to replace the battery on the M-F 1526 I'm going to replace it with Delkor if I get the service life that I should out of it, Just another 2 choices IMHO , Have fun & be safe doing it.
   / BATTERIES
can do... As with most information on the internet, there are mixed reviews on everything. From what I found, the "general" consensus seems to be between Deka (East Penn) and Interstate (Brookfield - Exide) as the best choice. Delkor Batteries looks to be an Australian Company. I couldn't find them in the U.S. Living in Florida high temperature operation is more of an issue for battery life than CCA. Thanks again for your input and have a blessed day!
FYI: I found the following articles...
   / BATTERIES #6
Hey Crawl ! Those are not actually bad choices ,The Delkor batteries are out of S.Korea & are owned by Johnson corp. & they claim to be the largest battery manufacture in the world in automotive . Thanks for the links (y)! & I'll have to check a few of them out.
   / BATTERIES #7
Two years ago I put an Odyssey battery in my 2009 M6040. 1150 CCA. And I keep it on a battery tender in the winter. It's tough enough, in the winter, putting my hinney on a frozen vinyl seat. And then, to have a dead battery - NO WAY.
   / BATTERIES #8
Have your significant other make you a seat cover from an old bath towel. Better than numb butt.
   / BATTERIES #9
I don't think he will need either being in Northern Fla. what say you 5030 & oosik :rolleyes: .
   / BATTERIES #10
I would sure hope not - can do. I have a foam "hot pad" that I put on my vinyl seat. At least, the buns stay warm. As I age and mellow - I find less and less reasons to do a project outside when it's REALLY cold. Patience is a wonderful virtue.
I DO have the cold wx clothing - Eddie Bauer & North Face, head to toe. But when used, I look like the Pillsbury Dough Boy. Comfort is great, mobility - limited.
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
2011 Chevrolet Traverse SUV (A50324)
2011 Chevrolet...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
