Leveling and smoothing very uneven prairie
   / Leveling and smoothing very uneven prairie #1
mtburr
Ford 661 Workmaster
I want to turn a former pasture into a yard and airstrip. The previous owner (my late father in law) had started plowing the land 50 years ago and found it was too rocky and so he gave up, leaving behind a bunch of plow ruts that have since overgrown with prairie grass. He used this land for a pasture for many years, and for the past 15 years it's been our residential acreage -- mostly useless for anything besides pasture because it's so rough. It's impractical to fill in these plow ruts; it would take many truckloads of dirt. The overall plot is 10 acres but I'm looking to smooth out about 3-4 acres of it for recreational uses including an airstrip for an ultralight aircraft. So ... how do I turn this rough prairie (with plenty of rocks and boulders beneath the surface) into smooth land without bringing in truckload after truckload of dirt? I have a 2WD 48 hp tractor (Ford 661 Workmaster) that may pull a small box blade, but probably not through overgrown turf. Should I be looking at a harrow or disc? Or maybe a rotary tiller and land plane? (I don't want to repeat my FIL's experience hitting boulders with a plow, and I don't need to turn it over that deeply, just smooth out the surface.)
P.S.: I searched the archives for smoothing-related discussions and failed to find an answer for my situation.
   / Leveling and smoothing very uneven prairie #2
Disc, disc and disc again, cross disc and re disc.
Hire someone with a bigger machine if need be.
May need a different tool to remove whatever rocks are left on the surface.
   / Leveling and smoothing very uneven prairie #3
Hire out a bulldozer to make the air strip. Otherwise you're just wasting fuel and time trying to do anything with a small tractor.
   / Leveling and smoothing very uneven prairie #4
I have 90% same issue, less the rocks. watching with interest. I also am putting in a runway.
   / Leveling and smoothing very uneven prairie #5
Personally, I would find a guy with a bulldozer and root rake. Rake it through to pull up roots and rocks, then use the blade to smooth and make the runway. You can follow up afterwards with a disc and box blade or whatever to do the final smoothing and shaping. Then reseed.
   / Leveling and smoothing very uneven prairie #6
Bingo. (y)
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
Tiger Mower Hydraulic Tank Connection (A55851)
Tiger Mower...
2019 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52707)
2019 CATERPILLAR...
2022 Kubota Z422-54 Zero Turn Mower (A57024)
2022 Kubota...
UNUSED RAYTREE RMBD50 50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
