Mowing Kubota ZD1511 Only does parked regens!
/ Kubota ZD1511 Only does parked regens! #41
Well low air in seat wasn’t the intermittently dying problem yesterday .
it kept dying today from a seat switch malfunction & eventually wouldn’t spin over to restart.
I temporarily bypassed the seat switch to mow all afternoon :mad:
/ Kubota ZD1511 Only does parked regens! #42
I’ve found this for the V1505 4cyl engine in the ZD1511 mowers :
This may make life easier
/ Kubota ZD1511 Only does parked regens! #43
Wow :mad: I couldn’t stand $700
At least this mower has 4 more years of emissions warranty.
Technology is Good & BAD but I do Love this Mower.
I just wished it had an 84” Deck & More HP ;)
An 84” deck might work for you, but even the 72” machines I have scalp more than I like.
84” would scalp a lot.
I‘m happy I didn’t buy a 1511 or 3990 now. This mandated DPF stuff on lawn mowers is so ridiculous.
I can see why so many commercial lawn companies just run big block gas zero turns now.
/ Kubota ZD1511 Only does parked regens! #44
That’s where you might want to spend your $700
/ Kubota ZD1511 Only does parked regens! #45
84” would scalp a lot ...
What height do you mow at ?
I’m 3.5” measuring blades off concrete floor & don’t scalp my rough uneven farm Ground
/ Kubota ZD1511 Only does parked regens! #46
If I have another dang parked regen now after the updated reprogramming: I’ll definitely check into this (y)
/ Kubota ZD1511 Only does parked regens! #47
Old thread resurrected lol
After Kubota remapped my ZD1511 : I haven’t had to do another parked regen 👍 thank goodness.
i need the power AND TORQUE of the 4cyl Turbo on my hills & thick grass. My old 1211 bogged pretty bad.
i liked the mower so well that I bought another ZD1511 72 SD deck 🙏
did kubota discontinue making these ZD1511 mowers ?
2017 SANDPIPER 5TH WHEEL RV TRAILER (A60736)
2017 SANDPIPER 5TH...
Vertical Steel Well Tank (A61570)
Vertical Steel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
