Husqvarna LGT 24K54 loses ability to go up hill
   / Husqvarna LGT 24K54 loses ability to go up hill #21
It has to bleed air out of the system. First couple times it might not do anything.
Well, that would be AWESOME if that was the case. Thanks Buckeye
So... Just keep putting it in drive and hope it bleeds the air out? There's a link in Lotsofgreengrass's post to a "How to bleed air out" but the link doesn't work... Should I be doing something to help this along?
   / Husqvarna LGT 24K54 loses ability to go up hill #24
Pretty sure I just ran it awhile, don’t think very long. Been awhile, I forget exactly.
   / Husqvarna LGT 24K54 loses ability to go up hill #25
How's about this: 1. Check oil level. 2. Place vehicle's drive axle on jack stands with wheels off floor. 3. Start engine and operate at low idle speed. 4. Repeat opening and closing bypass (tow) valve while alternately depressing forward and reverse pedal(s). 5. When vehicle starts to move, increase engine speed. 6. Repeat quick starts and panic stops until transaxle give full response. 7. Remove jack stands while placing vehicle's wheels on floor.
8. Recheck and top-off oil level.
   / Husqvarna LGT 24K54 loses ability to go up hill #26
Make sure the transmission is engaged with the wire to allow you to disengage to push it. I just watched I video of my first run, took about 5 sec and I drove it away.
Thanks Tom,
i'm a little confused: Jack up drive axle with wheels off floor but then "once it starts to move"... How's that gonna happen?
Thanks again, buckeye. The transmission is engaged. I have a feeling you rebuilt yours properly and that's why it ran after 5 seconds. I put mine in "forward" drive for a good 8-10 seconds and nothing. The wheels did buck once, but, that was it. I went forward and back - up on jackstands - 4 or 5 times.
Would you think - if things were ultimately okay - that I'd be able to spin wheel hubs with no resistance?
   / Husqvarna LGT 24K54 loses ability to go up hill #29
I had a somewhat similar issue and posted. That thread may or may not offer some help. In my final post to that thread I explained that it did get better but by then I had determined to sell it. Got a J Deere replacement and immediately noticed the difference between my quite old unit and a brand new one. BTW - the Husqvarna has - I guess - an electronic push/pull control to activate the mower (the JD unit has a lever)- and when I put in a new battery mine did better on hills - but I have no idea if that is at all relevant.
The other thread: Lawn tractor - loss of power
   / Husqvarna LGT 24K54 loses ability to go up hill #30
What Tomplum said looks familiar.
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
