Problem with my Select-O-Speed (10 forward and 2 reverse speed powershift) Tranny on my 1965 Ford 3000
   / Problem with my Select-O-Speed (10 forward and 2 reverse speed powershift) Tranny on my 1965 Ford 3000 #1
Old Guy 14
1965 Ford 3000
As I was leaving the pasture I stopped my tractor to dismount and open the pasture gate. As I started to dismount my wife beat to the gate and opened it for me. I released the parking brake and put the selector in 3rd gear. The tractor would not move. Thinking I may have not placed the selector in the proper positions I placed the selector in the neutral position and then moved the selector back to the 3rd gear selection. The tractor still did not move. I did noticed that when I moved the selector to the neutral position the tractor relaxed as it went out of gear, but when I put it back in 3rd gear it gave no indication that it had not gone into in gear. I am not sure what is going on and could sure use some insight as to what I should look for and correct to get my tractor back in business. Thanks.
Old Guy 14
   / Problem with my Select-O-Speed (10 forward and 2 reverse speed powershift) Tranny on my 1965 Ford 3000 #2
Does it work in any gear? When our 5000 with select-o-speed quit it was in all gears. Problem on the 5000 was main input spline broke which cost more to repair than tractor was worth.
I replaced the select o speed with standard manual transmission and it is still running today
   / Problem with my Select-O-Speed (10 forward and 2 reverse speed powershift) Tranny on my 1965 Ford 3000 #3
Old Guy 14
I like Fords, but have never owned a select-o-speed.
I never did have confidence in that 1960's Ford tractor system.
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
