Duel fuel
/ Duel fuel #1
jdmeth
Palatka, Fl
JD 1023E Kubota 7100D
I have a Westinghouse 9500 watt duel fuel generator. A year ago when it was new I put about a gallon of gas in it and ran it for an hour and then shut off the fuel so it ran out the carburetor. Every few months I would run it for a few minutes. A few months ago I needed it for a power outage. I put some fresh gas in it and it ran for about five minutes under load and died. It would fire but not continue running. Figuring the carburetor was clogged I hooked up a LP tank. It ran about 15 seconds and died again. Again it will fire but not continue running. Any ideas?
/ Duel fuel #2
Yep.....suggestion!
Get a dual fuel generator.
Your fuel may be dueling with the generator engine.
/ Duel fuel #3
I am not really familiar with that unit, but seeing as how it shut down on both fuels, maybe there is a problem with the generator output. Is it being over-loaded or perhaps the mains/standby switch is not working.
/ Duel fuel #6
Might want to check yer coil, some times a bad one will run till it gets warm than craps out
BTDT...................
/ Duel fuel #8
Does not run at all, just revs enough to disengage starter.
As suggested, check the low oil/ low oil pressure sensor. Found my Generac doing this and turned out to be the oil pressure sensor was clogged. Badly designed sensor appearently as a lot of people had the same problem. I just ended up bypassing it.
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2019 International DuraStar 4300 26ft. Reefer Box Truck (A61573)
2019 International...
