Should I cab or not. Getting ready to buy
   / Should I cab or not. Getting ready to buy #202
One thing I have noticed about cabbed versus non-cabbed tractors: If you are on the tractor for long hours out in the wind and weather, the cab makes it much less fatiguing. 8 hours on a non-cabbed tractor will leave you dehydrated and physically wear you out, but is much more manageable with a cab.
   / Should I cab or not. Getting ready to buy #203
For those worrying about working on the woods with a cabbed tractor, you can always dump a couple grand on the tractor and make it almost bullet proof. :)
The bottom of the tractor is also shielded.
   / Should I cab or not. Getting ready to buy #204
I really like that. My M126X is my bush hog tractor and she has a few battle scars.
Home made or pre fab kit?
Very nice. Looks like it makes routine maintenance a bit more challenging though.
   / Should I cab or not. Getting ready to buy #205
We have a couple of companies dedicated on fabricating all kinds of protections and shielding for tractors and a the bigger dealers will do it in house as well. Main use of these tractors ends up being either logging or land clearing, mainly brush mowing as we don't really use skidsteers for that. They also are setup with forestry tires.
I'm sure they have pre fab kits, however most are custom fitted to the tractor and to the costumer likings. All the panels are easily removed for maintenance and there are small doors built in so it's still easy to pull the dipstick. Yes, it's makes it having a couple more steps for maintenance but it keeps the tractor protected and we all know that things get expensive in an hurry if a branch breaks a glass or rips the roof of the tractor.
Some more pictures:
Nenhuma descrição de foto disponível.
   / Should I cab or not. Getting ready to buy #206
If you don't get the cab factory installed you can
kick youself in the ass later! The aftermarket cabs
they are cheaper but leave a lot to desire!
willy
   / Should I cab or not. Getting ready to buy #207
One thing I noticed about working outside in the summer time late afternoons, on my canopy-equipped open-station tractor:
The fresh air outside sure feels good after being cooped up in an air conditioned factory or house for most of the day.
   / Should I cab or not. Getting ready to buy #208
One thing I'm noticing on cabbed vs non-cabbed tractors is that it causes quite the debate on a tractor forum!
   / Should I cab or not. Getting ready to buy #209
wolc123 yes for you after work but how would it
be during the say from 12 noon to 7 in the evening???
In the cool of the evening when its nice and cool or
sometimes very early in the morning But not very
often here in Texas as at 9 pm temps can be in the
upper 90's
willy
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A58018)
2016 FORD F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1994 International 3800 Bus (A54814)
1994 International...
