The front axle has three bevel gears. Why would I choise Hypoid gear lube?
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
With only bevel gears in the front axle differential and drives out to the wheel axle, I see no reason to use the stinky sulfur rich hypoid gear lube.
"Change My Mind" ;-)
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #3
I've used Mobil 1 75/90 gear lube since new. Like the idea of having the extreme pressure additives in the front axle. Lots of pressure on those gears and bearings at times
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #4
Use the manufacturer's recommended gear lube. Some gear systems may contain non-ferrous metals. This likely requires GL-4 gear oil. If there are no non-ferrous metals, GL-5 with the EP additives is the correct choice. The so-called "stinky" gear lubes with EP additives tolerate much higher loads without shearing. You won't smell them once they are installed in the gearcase. I add some MOS2 to my gearcases which further reduces friction. I also use Molybdenum Disulfide fortified NLGI II greases on my machinery. The EP aditive "Moly" is found fin engine oils, greases and other lubricants. It is also used in gun lubricants. The stuff is very slippery and promotes a considerable reduction in friction and tolerates high heat. It reduces gear wear under high load conditions.
Is your mind changed?
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #5
Just plain bevel gears don't need the lube made for hypoid gear designs. A hypoid gear set is helical and off-set with a small contact patch so there is more rubbing going on than the straight gears. That is why it needs a high pressure lube. I have used hypoid lube in bevel gear boxes though.
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #6
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #7
Kubota fills their front axles with hydraulic oil (UDT or SUDT2, I forget). But they spec hydraulic oil or gear oil for the axle. The thinner stuff will rob less HP by amounts you couldn't tell by operating the machine. But the thinner stuff also leaks out of seals easier.
I just put thicker gear oil in mine. Stopped or slowed the leaky seal on one of the front steering joints. Need to take it into Kubota before the warranty is up in December to get the seal properly fixed. But thick gear oil is fine for now during my busy season.
   / The front axle has three bevel gears. Why would I choise Hypoid gear lube? #8
Guess you forgot about the center section with it's differential.
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
1269 (A50490)
1269 (A50490)
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
