Ford 1720 Repair Manual Question
   / Ford 1720 Repair Manual Question #1
lpsomero
Ford 1720
Good day all,
Quick question. I ordered a service manual off good ol Ebay. The one I ordered has a copy right date of 1989 and has printed on the inside cover tractors up to 1988 year model. My tractor is a 1995 1720 and if I'm not mistaken they had a wiring harness change in 92? Question is will this manual be fine or do I need to do some digging to find one for a 95 later models?
Thanks for the help!
   / Ford 1720 Repair Manual Question #2
Good day all,
If it was me, I'd get the correct year manual especially since you know or suspect there was a wiring change.
   / Ford 1720 Repair Manual Question #3
Good day all,
That's a nice size tractor and has features a brand new tractor would be hard put to beat.
Nice engine, transmission, good weight, heavy 3pt with draft control....4wd & power steering. Nice old style construction.
Tractors are manufactured in batches and then sold over a period of years. It's entirely possible that a tractor could sit on the dealer's lot or in warehouse storage for years and yet it would still be the new year when sold. Even though it might have been manufactured a decade before. So it is difficult to be sure just knowing the year sold. That's why with tractors the parts and changes go by serial number instead.
I'm betting that your service manual also has a list of serial numbers covered.
From tractordata.com, here are some serial numbers for the Ford 1720:
1987: UL21001
1988: UL22701
1989: UL26556
1990: UL28601
1991: UL30784
1992: UL32230
1993: UL33920
1994: UL35013
1995: UL36435
1996: UL37607
1997: UL38466
1998: UL40069
1999: UL41414
2000: UL42699
rScotty
Thanks for the help guys.
   / Ford 1720 Repair Manual Question #5
I have a 1994, 1720, by serial number and have been trying to find a genuine service manual with a detailed wiring diagram and parts diagrams for the various harnesses and associated relays and switches. No luck so far and the local New Holland dealer claims they don't have those resources available either. It seems the ignition harness no longer is made and my tractor has a number of systems that have been bypassed or disconnected so I've got a big job, not the least of which is to recreate the glow plug circuit. Can anybody help or point me to a good resource? Thanks, much.
   / Ford 1720 Repair Manual Question #6
Rob,
Were you able to locate a source for the needed service manual? I´d also like to locate one for my ´89 Ford 1720 with FEL. Any guidance is helpful.
Thanks,,, - BarnieTrk
   / Ford 1720 Repair Manual Question #7
Not sure which years the wiring diagrams are for here.
1271 (A50490)
1271 (A50490)
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
