3PH Capacity
/ 3PH Capacity #1
Kevin1967
Member
Ford3930
If you had an implement that manufacturer recommends a lift capacity of 1500# would you buy, and use a tractor that has a maximum lift 24" from pins 1676# or go for a tractor with higher lift capacity?
/ 3PH Capacity #2
My tractor has a lift capacity of 1389 at 24" and 1900 at the lift ends. I bought a power rake that was about 1300 lbs. The tractor handled it just fine but even with the loader felt a little unstable. My biggest fear was hitting a pothole and cracking the tractor in half with the rake in the air.
Ultimately I had little use for it and sold it this year. But if I were regularly using a heavy implement like that, I want a bigger tractor. Like something with 2000lbs+ lifting capacity.
/ 3PH Capacity
Thanks, I have a NTD that is 1000# (empty) manufacturer recommends 1500# lift capacity, and I have to use it on some rolling hills and drive up a steep trail to get to one of my fields. I was a little concerned about stability and doing damage to my lift arms due to bouncing.
/ 3PH Capacity #4
While lift spec may be 1,500 pounds, real life may be 1,3450 - 1,400 pounds on a high engine hour machine.
On even a slight slope your tractor front wheels may lift off the ground initiating a rollover due to too much rear weight.
/ 3PH Capacity #5
What is the implement and what does it actually weigh? I dont put much stock in implement MFG's "suggestions". They are usually ultra-conservative for the CYA factor.
/ 3PH Capacity #6
First thing I'd want to know is how heavy is everything forward of the rear axle?
If I recall/understand correctly the lift rating of a tractor 3pt is measured with the front of the tractor chained to the ground so it's direct comparison of the hydraulic lifting capacity between tractors. ....so not exactly real world useful, but then not all measures made for the sake of comparisons are based on real-world use cases.
So I'd be more inclined to pay need to the tractor manufacturer's recommended implement weights than I would a implement manufacturer's recommendations ....though even the tractor manufacturer's recommendations can be a bit conservative since they are likely based upon the worst case tractor configuration (e.g. no loader or front weights).
Though whichever recommendations are looked at it's probably wise to be cautious about exceeding the recommendations given the manufacturer's aren't always clear on why their recommendation is their recommendation .....
/ 3PH Capacity #7
I am (maybe wrongfully) assuming this is the 50 hp 5500 pound tractor in the OP's profile?
/ 3PH Capacity #8
Yeah, I can understand that assumption I was just a bit thrown off since the marketing brochure number for my tractor lists ~2600lbs lifting capacity, and the manual says 3750lbs at ends and 2650lbs at 24" behind ...and yet the implement recommendations in the tractor manual generally top out around 1/3 that weight for short implements (880lbs for a box blade) and decrease the longer the expected implement length.
I have used a 84" 1000lb 3pt disc harrow (manual recommends max 770lb 72" wide for pull type) with that tractor so I know the recommendations can be low, though I can also say it's definitely noticeable when it swings/shifts (while lifted) during a turn (and that's with full set of rear wheel weights and the heavier loader option for the tractor). Sort of feels like it's starting to cross a bit into the tail wagging the dog scenario even though the front doesn't feel light.
So it may be an older tractor with lower pressure hydraulics (and more realistic 3pt lift capacities identified) that has a wider/heavier frame, but I figure the simplest thing would just seem to ignore the lift weights and consider how much weight is forward of the rear axle and the overall total weight/size of the lifting tractor. .....at least if it's an implement that will be completely lifted/carried by the tractor.
/ 3PH Capacity
No, not my 3930, I am looking for a new, smaller lighter tractor that I can still use with my NTD. My NTD weighs 1000# empty.
/ 3PH Capacity
The implement is a NTD. Empty it weighs 1000#s. I can put another 3-350# in it of seed.
/ 3PH Capacity #11
I have found the implement manuals to be laughable at best and no where close to real world.
They never used to put this crazy stuff in manuals. People just did what worked. Its all about CYA for the manufactures.
MAnual says max cutter for my tractor is 7'/1000#, I use 8' 1620#. IT says max 2x16 plow and I pull a 3x14 with ease. Max pull type disc is 7'/880#....I pull a deere 210 ~11'....and probably alot heavier than 880#. SAys max 6' rear blade....well the tractor is 6' wide so how do you cover tracks when angled? I use a 8' 1250# hydraulic blade. Says most I can tow is 7700# on a trailer. I have no issues with my 12k dump loaded to capacity.
The manual and its limitations are great if you are inexperienced with tractors. But dont treat them as gospel that should never be broken
/ 3PH Capacity #12
IT would help if we knew what tractor you were considering.
I assume NTD is a "no-till drill"? I didnt even know you could get one in 3PH? Are you talking about something like a brillion seeder?
/ 3PH Capacity
The tractors I am considering is a Kioti CK3610, DK4510. CK3610 weighs 2646#, FEL with 66"bucket weighs 981#s, 3 ph lift capacity 1631# 24" from pin. DK is not in stock currently. The DK brochure says the Tractor weighs 3373# w/ AG tires, FEL w/ 72" bucket weighs 1,085# totaling 4458#s. The Dk 3ph lifting capacity is 2,716 pounds.
I have a Genesis NTD for food plots, and such. The Ford 3930 is just too damn big and a hassle to transport to and from KY and TN so, I was wanting a smaller lighter tractor. However, I wanted to make certain due to the rolling hills I have a stable platform that can handle the load.
/ 3PH Capacity #14
I have a CK3610 and would probably recommend a DK for what you are considering. As nice and beefy as the CK is, the DK is another league up in weight, strength and capacities. Should fall right in the middle of the Ford and the CK3610 in size.
/ 3PH Capacity #15
I'd aim for the DK, but I think either would do it if you are correct about the weights.
/ 3PH Capacity
Thanks guys!!! I knew I could count on you guys!
/ 3PH Capacity #17
Nor did I comprehend NTD.
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A61568)
2000 Thomas Built...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A61165)
2002 Ford F-250...
2006 Ford Crown Victoria Sedan (A61569)
2006 Ford Crown...
New/ Unused Wolverine 72in Quick Attach Grapple Bucket (A61166)
New/ Unused...
