Loose hay
/ Loose hay #1
wolc123
Who remembers bringing it in loose ? We brought it in that way, until my grandad bought a square baler, when I reached my teens. We used an old sheet metal loader, that attached to a wagon. Grandpa would be on the tractor and my dad and uncle would be leveling it out on the wagon.
I fondly remember those days. It was so nice to not have to deal with twine or wire, and to just go up in the loft and pitch down what you needed at chore time. The nightmares began for me with that baler. Handling those heavy bales up in the hot hayloft was tough on this skinny kid.
Grandpa loaded the elevator, down in the cool breeze, while I roasted up in the loft, stacking them bales. How I missed the loose-hay days.
The old barns that my great great grandad built, shortly after the Civil war, fell into disrepair, and I am currently in the process of taking them down. I hope this old hay fork and trolley dont get busted up too bad when I pull down the frame of the last one that is still standing. I would like to hang it up in my new pole barn, as a reminder of the good old days of loose hay
/ Loose hay #2
My grandfather had two barns with trolleys. He was having the hay baled by my day and I only saw him use the trolley once for a small load, when there was no baler around. The pick-up had double spears instead of a grapple.
/ Loose hay
I still remember the clouds of dust when that fork dumped a load up in the loft. I also remember one time when something broke on the trip mechanism, and my grandfather got up on an extension ladder to fix it.
My dad wanted to do it, but I remember grandpa telling him, "I'll do it because you got young kids at home to take care of". I am a little scared of heights myself, which is why I am not going to make any attempt to recover that fork and trolley until the barn frame is smashed down on the ground.
The other barn that I took down had a rail all the way across the top, and this one only goes about half way. I removed all the siding from that timber frame structure, and cut out most of the diagonally braces. I noted a slight lean to the frame after that. The next day, it fell down on it's own, with the weight of 4 layers of ashfault roofing on top of cedar shakes pounding it flat as a pancake.
I have the current one cabled to a tree out back, to keep it from falling before I finish removing the siding. It already has a good lean in the opposite direction and would certainly go over on it's own otherwise, before I finished stripping the siding.
/ Loose hay #4
The barn in which I store hay had the system. It was built after the Civil war. The railroad passed by one day, shot up a lot of sparks from the steam engine and burned the barn down. The railroad took ownership and rebuilt the barn. That was over 100 years ago. The barn still stands, but the loose hay forks and system are mostly dismantled. I still have the forks and trolley. Never put up loose hay, just bales.
/ Loose hay #5
My grandfather would mow the hay in his orchard using a scythe, My father and I would rake it, ted it; and trailer it home to put in the loft of the sheep shed. I was the little guy whose job it was to compact the loose hay in the eaves. I was (am) allergic to grasses and would come out coughing and covered with hives. No pleasant memory there.
/ Loose hay #7
The hand hewn mortis and tenon barns are a thing of beauty. Thanks for posting.
I've done some small projects using the mortise and tenon method along with hand hewing a few logs.
Those guys back in the day were real craftsman. No powered tools or winches.
/ Loose hay
I repurposed many of the hand hewn posts and beams from my great great grandad old barns, to frame a loft, woodshop, and metal shop inside my new pole barn. I roofed and sided those with his old, weathered American chestnut barn siding and granary wood.
/ Loose hay #9
Amish still do it that way.... Gentiles don't.
Not around here they dont. The Amish in Chester & Lancaster Counties make round and small square with engine powered balers pulled behind Percherons
/ Loose hay #10
Growing up 15m from here Dad (rip) and I got up hay loose for his horses. He & I built the small stable (still standing, I don't know how) he bought sawmill lumber and I don't remember using a level.
One bay he put down pallets. He would use hay rake into wind rows then I'd walk along behind trailer pitchforking it in, pulled by Farmall tractor. Pull alongside I'd pitch into that stall tight as possible, barely shut the door.
I'll see Mom (94) shortly for mother's day.
I'd pay $1,000 to relive one day with Dad.
/ Loose hay #12
I repurposed many of the hand hewn posts and beams from my great great grandad old barns, to frame a loft, woodshop, and metal shop inside my new pole barn. I roofed and sided those with his old, weathered American chestnut barn siding and granary wood.View attachment 697865View attachment 697864
Wow! I really like that room.
Our horse stable is finished except for the tack room. I'm waiting and hoping lumber prices to come down so I can build the room. Concrete finishers made a smooth floor for the room, and it has a window. Your room gives me ideas!
/ Loose hay #13
Amish around here don't make hay. They buy it from the same guy that makes my hay.
/ Loose hay #14
I sell hay to the Amish
/ Loose hay #15
I remember the loose piles in the middle of fields. Don't recall details of progression from those to moving balers. Seems like someone had to ride along beside a baler for a while to tie off the bale, or something, before auto tie off. Think had twine first and then wire.
Yeah, remember also hauling rectangular hay bales. Last guy I hauled hay for was on a farm west of Stonewall, OK. A tornado came through a year or so later and killed the guy and 8 others.
/ Loose hay #16
I remember the old loose hay loader days and am thankful they got replaced with the much easier square bales and silos .
/ Loose hay #17
I was about to 'remember' the whole deal [rather than just putting the hay in the barn] just when cydledude spoke up. My first job was to follow the hay loader with a pitch fork and pick up all that the loader missed. Really hot and dirty.
Later I got the 'privilege' of being up on the hay wagon to distribute the hay when it came up the loader. That took real balance to keep from falling off that bouncy hay. But the ride in to the barn sitting on top of the hay with a full wagon after such hard work was delicious.
Then I loved the sinking of that hay fork deep in the pile to lift it up to the peak was somehow the most satisfying part of the work for me. Not sure why but somehow that was the part that meant we had beat the weather and the equipment failure and all the other problems and had our harvest stored up.
But then having to climb up in the hay loft at 5 am to fork hay to the cows was NEVER a welcomed job for me. Dusty and hard work before getting ready for school. BAH.
/ Loose hay #18
Our hay was cut with a sickle mower, side delivery rake rowed it up, hay rake gathered it into piles, we pitchforked it into the wagon, pitchforked it up into the barn, and then pitchforked it to the back of the barn. Thankfully pitching it back down into the wagon and then to the cows was much easier.
/ Loose hay #19
My Great Uncle would harness up Molly and Mae and towing a wagon and Loader/Elevator behind it loaded the hay as it fell on the wagon. Then to the barn with a double spear fork. I had to drive a certain speed on the old redbelly Ford so when the load from the wagon hit the track there was enough inertia to trip it and carry it into the barn. It would hit the Centre block and stop. Or stop sooner.
Somehow the twin spears released (rope to 'fingers' on bottom of Spears) to drop the bundle.
25¢ a day sometimes! I much preferred plowing with the 44 Massey.
/ Loose hay #20
Funny how this brings back so many memories. Dad worked at Sears many years ago. Somehow someone he worked with had kin in Vermont who was a farmer. That year his hay crop was about nothing, lack of rain I assume. He was desperate so called Dad (we had a lot that year), so one evening that Fall this old pickup truck comes down driveway, poor guy drove Vermont to Virginia! We felt sorry for him and loaded all he could carry. I remember it was cold and his door window missing, we taped clear plastic over it.
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
JOHN DEERE 1730 - 6R40", 11R20" VACUUM PLANTER (A64278)
JOHN DEERE 1730 -...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
